I was pondering earlier today - how did we arrive at the current rail and wheel design?
I expect a lot of thought has gone into it over the years and that it remains the correct design to use.
However, with all the poor adhesion lately I can't help but wonder whether alternatives might be more suitable.
Thinking about car tyres - having grooves on the wheels or rails would presumably help with grip. I can't believe no one has thought of this before therefore I assume there must be a good reason why it can't/shouldn't be done.
Maybe to do with wear+tare (tear?), noise, or maybe it just slows trains down too much in good conditions.
But then I got thinking - if indeed grooved wheels *is* a good thing, but only in certain conditions, what if we were to devise a way to have both smooth and grooved wheels available as and when required?
i.e. lower the correct wheels into position and retract the undesired ones.
Now obviously, assuming that any such system were safe to use at speeds above 0.5mph there would probably be a cost, and a huge one at that, to implement such a system - not to mention the added maintenance cost.
But if, and I emphasise the if, it were possible (and desired) - might the benefits actually outweigh the costs?
I'm no money expert but just thinking about the amount of money lost due to poor adhesion alone - late running fines, cancellation fines, delay repay, lost revenue from delayed/cancelled services causing passengers to look elsewhere.
Does all this add up to be enough to counter the outlay?
I think I know the answer, but thought I'd throw it out there for discussion anyway...
