Railcard discounts beyond West Drayton to Reading
bakerstreet
29 Nov 2009
Generic question,
Is there a smart card which is valid on GWR/Elizabeth Line on which you can add a standard national railcard with the smart card charging pay as you go fares and capping. Or any combination of the above.
Specific scenario
Say I want to travel from Ealing Broadway to Reading with a nationally available railcard discount. Currently, I could buy a paper ticket with the discount or I can use contactless without the discount. I’m wondering if there is a third option of a TOC smartcard.
You can either use:
  • Contactless PAYG, which will charge you the undiscounted adult fare. In many cases this will be more expensive than paper tickets, because of the Railcard discount you could get, and/or because Off-Peak fares are charged at different times (e.g. there is no evening peak for the paper fares if using Elizabeth line services).
  • Conventional single/return tickets with the full Railcard discount. These are available in eTicket format, but seemingly not smartcard format, for this journey.
What you can't currently get is a PAYG option that provides Railcard discounts, as is the case for KeyGo on GTR for example. So you have to choose between PAYG and Railcard discounts.
bakerstreet
29 Nov 2009
Thank you, that’s what I suspected. I just wanted to check I wasn’t missing something
