JohnE1959
Does anyone know what process network follow when trying to trace earth faults on the Signalling Equipment?
Just to clarify, what caused the disaster at Clapham Junction wasn’t an earth fault. It was caused by not cutting back a wire removed during stageworks as part of resignalling......... minimise the possibility of causing a 'wrong side' indication during the work - Clapham Junction 1988 is always a reminder of what can go wrong.
Thanks, I was aware - I was trying to indicate that working on signalling equipment to find even an earth fault can have potential perils if not done correctly.Just to clarify, what caused the disaster at Clapham Junction wasn’t an earth fault. It was caused by not cutting back a wire removed during stageworks as part of resignalling.
One that is more relevant is the Severn Tunnel rear-end collision in 1991, where a second train managed to get admitted to the tunnel on a signal that changed to green while the fault finding team were working on the axle counter equipment.Thanks, I was aware - I was trying to indicate that working on signalling equipment to find even an earth fault can have potential perils if not done correctly.
Wasn't that down to the signaller agreeing to them resetting the axle-counter while there was a train in section? Unfortunately there was no form of co-operative reset, and the axle-counter was shown on the panel pretty much as though it was a track-circuit.One that is more relevant is the Severn Tunnel rear-end collision in 1991, where a second train managed to get admitted to the tunnel on a signal that changed to green while the fault finding team were working on the axle counter equipment.
