The wonders of technology
I wonder how the bell was operated. Was there a pull cord from the cab? I think the current automated USA rhythmic ding-ding-ding is a more recent invention.
A photograph here..
you can see the metal rod that attaches to the bell, and is held by a triangular brace, that connects to a further metal pipe going right along the top side of the running plate to the cab. Presumably this rocked forwards / backwards to ring the bell.
This locomotive was built in 1930 at Derby as 6152 The Kings Dragoon Guardsman. In 1933 the LMS was invited to send a locomotive and train to the Century of Progress International Exposition in Chi…
preservedbritishsteamlocomotives.com
6100 had several changes of appearance in the US /Canada.. it was dissassembled for transport and reassembled in Canada.
Record - Library and Archives Canada
www.bac-lac.gc.ca
at various times it ran with cow catcher, and a special central chromed lamp iron with a hook to hold the coupling chain rather than letting it fowl the cow catcher. It also went with additional lamp irons on the smoke box sides, and of course was fitted with a headlamp & electric cabling for it.
It was later fitted with the bell (not all images show it present), but retained that hook for the coupler, so the base must have had a cut out to fit it, and presume the lampiron was cut off.. this was still present in its return when displayed at Bromwich, but the cable to operate the bell is gone, though the front mechanism was present.
Interestingly the nameplate shows space for a crest when it reached Vancouver, but not present in all US images…
in some later pictures it has the US fittings and the new nameplates commerating its visit, presumably these were at UK return but prior to returning to UK service (Inc the Castle Bromwich visit referred to above).
on its return, it had the bell but without mechanism, the front name plate “The Royal Scot” and bolts on the bufferbeam from the cow catcher, but the light and extra smokebox mounted lamp irons were later removed, and a new nameplate. It also had a new lamp iron sticking out infront of the bell.
Taken from a print in my collection, no further details available. Built by the North British Locomotive Co, entering service as LMS 6152 THE KING'S DRAGOON GUARDSMAN during June 1930. Exchanged identity with Royal Scot Class 6100 ROYAL SCOT prior to a tour of the United States of America in...
www.flickr.com
At Bressingham, it reacquired the bell, but lost the aws protection plate added by BR, and of course was a fully rebuilt condition. Interestingly if you look at 46100 in its condition today, the bufferbeam is again smooth, but riveted, including the front running plate.. its actually 46115 thats got holes filled all over it, and uses bolts not rivets on the front running plate, though I put that to 46115 being more “ex-BR” and 46100 having preservation era repairs.
doubtless theres more mods not mentioned here., as side of the rebuild of course.
finally, whilst not wishing fuel conspiracy rumours, but 6152 did develop a subtle change in appearance..
here in LMS red it has the outline of its centre lamp bracket, where it should be, front centre right next to the vac pipe, and of course that typical smooth front buffer beam..
railway photographs from the last 100 years
railway-photography.smugmug.com
but later in life its centre bottom lamp bracket is now offset to the right, and the bufferbeam has a lovely set of rivets in two symmetrical rows of 6 to the inner sides of the bufferbeam, as if they were previously used to hold something… this bears up on its rebuilt images.
Best viewed Original size. Kingmoor (12A) shed's rebuilt Royal Scot class 7P 4-6-0 46152 (formerly named "The King's Dragoon Guardsman") receiving routine servicing at Holbeck (55A) MPD, Leeds, not long before withdrawal - c.1965. Originally built (North British, Glasgow, 1927) as LMS 6100...
www.flickr.com
I dont see an obvious reason for this uniqueness of 6152, but it doesn't infer anything, its just an oddity… but in that subject it would be unfair to miss this oddity out…if Riddles designed a 7P 4-6-0 is this what it would look like..
Royal Scot class 4-6-0 No. 46106 'Gordon Highlander' at the ex-LMS Gloucester (Barnwood) Shed, 22B. This loco is the only member of the class fitted with straight smoke deflectors.
www.flickr.com
46106 with its BR Std smoke deflectors.
