Should Reston station have been built, and could it be served by Scotrail?
kez19
15 May 2020
Dundee
Moderator note: Split from
Rather ironically Jenny Gilruth will be opening the newly reopened Reston station on Monday - the same day as the new temporary timetable comes into operation.
I went passed the build of that station on my journeys to England which trains are stopping at that stop and will it include Scotrail? (maybe asking a stupid question here) as wouldn't that be the furtherest station for Scotrail to use since the last one is Dunbar?
I can't imagine the press are going to give her an easy ride! No doubt most questions will be about the new timetable than about the opening of the station.
nah I think quite the opposite the media will be silenced on the new timetable but it be mostly fanfare for the station that will be highlighted.
Christmas
10 Mar 2018
According to rail map.org it's only LNER and TPE that will be calling there, although XC and lumo both pass through. It wouldn't do lumo any harm to stop there as they would easily make up the time when they get stopped further on their journey.
kez19
15 May 2020
Dundee
It sounds good the other operators are stopping at it but isn’t Scotrail missing the trick here?
I know I’ll probably be told that the other services will pick up traffic to Edinburgh, as on the other the station I think of similar is Morpeth to the outskirts of Newcastle (Northern mostly), but you will get the odd LNER/XC (and Lumo?) stopping but all operators are picking up (correct me if need be).
Starmill
18 May 2012
Bolton
Not particularly. They don't have any train crew who sign the line between Dunbar and Berwick-upon-Tweed, and they don't really have sufficient electric units to extend their Dunbar services to Berwick-upon-Tweed. It would also be very tricky for them to acquire rights because there are so many other trains already running on the same lines. It would add lots of cost to fix all of the above, and serve essentially nobody except for people going to and from Reston, which will be hardly anyone, so they would end up running largely empty trains.
Scottish Ministers did a deal with TPE to make some stops by offering to cover part of their costs. This was much cheaper than extending a ScotRail service.
ScotRail also don't run any trains to Lockerbie, there's no technical reason why not other than it would just be very expensive for relatively few passengers.
och aye
21 Jan 2012
So Lockerbie will no longer be alone in being a ScotRail operated station without being served by a ScotRail service. Dunbar will be joining that list on Monday too, albeit for different reasons!
kez19
15 May 2020
Dundee
I’ll ask this which is a negative point of view, what’s the point then in the station if the footfall won’t be there?
Seems to be then money wasted?
I should also partly correct myself the furthest Northern go is Chathill and believe is it one service each way and at certain times? (far from being expert here and apologies)
Starmill
18 May 2012
Bolton
Indeed. It has been built because Scottish Borders Council and the Scottish Government wanted there to be a station there, not because it is good value for money. It will be very little used.
kez19
15 May 2020
Dundee
In my mind initially when I read up on this I thought it be because locals wanted it and I thought all operators would use it but if above is pretty much true, the money for this could have been spent elsewhere
Starmill
18 May 2012
Bolton
Indeed. A station at Abronhill or Bonnybridge would have cost approximately the same amount of money but would have been served by hourly ScotRail trains between Falkirk and Glasgow. Notwithstanding any emergency timetables, of course...
Davester50
22 Feb 2021
Reston's 20 miles away from the nearest Scottish station, those places are what? 3?
Starmill
18 May 2012
Bolton
The village is only approximately eleven miles away from an existing railway station.
Reston has a 2km catchment of fewer than 500 people. The other two have more than 10,000.
The new station will have just seven services per day, at significant additional cost. Bonnybridge or Abronhill could have had twice as many services at near zero cost.
Davester50
22 Feb 2021
How much did the Beith re-build cost? Maybe they could have spent the money from that on the Central Belt stations?
Good places outwith there are getting infrastructure built.
kez19
15 May 2020
Dundee
I know this question maybe a bit off topic but is Reston served by buses to either Edinburgh (Dunbar) or Berwick?
Starmill
18 May 2012
Bolton
There isn't a station in Beith but perhaps you mean the Borders Railway? If so I would note that there are six Central Belt stations along it. There is also significantly more population in Galashiels than in Reston, and there was no other nearby railhead.
kez19
15 May 2020
Dundee
according to wiki (if this is the one..) https://en.wikipedia.org/wiki/Beith_Town_railway_station
Beith Town railway station was a railway station serving the town of Beith, North Ayrshire, Scotland. The station was originally part of the Glasgow, Barrhead and Kilmarnock Joint Railway.
but Google pops up Glengarnock though when you type above...
TPO
7 Jun 2018
Most Scotrail timetables north of the central belt were so shockingly bad before this, it must be a nightmare now.
Maybe the cost vs benefit of subsidising lightly used rural lines needs to be subject to a (UK wide) public conversation.
Especially as Scotland gets far more money per head than England (or Wales) do, thanks to the Barnet formula.
TPO
Davester50
22 Feb 2021
Apologies, Breich, is what I meant. Best part of a couple of million for 2000 usages. Great value!
Oh, I agree that Reston is much less deserving than other Borders villages and towns, but to try to say the already vastly better served CB is more deserving is a bit of a joke, IMHO.
Starmill
18 May 2012
Bolton
Only if you've got a chip on your shoulder about the Central Belt. And I could name a whole long list of better uses for the money spent on the TransPennine Express subsidy, such as retaining some of the withdrawn trains to Aberdeen and between Dundee and Arbroath. Stations at Newtonhill, Cove or Persley, or Culloden or Luncarty would have been significantly better value than Reston, and less costly to serve.
jayah
18 Apr 2011
Except that is exactly what people building/repairing pallets at a factory near me got , likewise bus drivers at a depot near me got 8.9% . It clearly is possoble contrary to what you are trying to say .Both sets of workers organised by a union that organises some railway workers as well .
And yet rail workers continue to negotiate for decent payrises . If they didn't and hadn't for years there wouldn't be such rhetoric about them being overpaid .
Pay rises actually has very little to do with unions. Railways were heavily unionised in the 1980s but had to face a monopoly buyer of labour and competition for public spending. It is ironic that the unions perceive they have more power with the ability to call out more workers on strike, when it is actually market forces that caused the arms race in train driver pay.
The bus drivers in Ilkely will have got a rise because the industry simply cannot recruit and retain without one. No bus drivers, no business. A lot of businesses are facing a quite painful adjustment and with it the realisation that we aren't all rich enough to have people bring shopping to the door and wait on us in pubs and restaurants.
Davester50
22 Feb 2021
Oh, come on. 2 Million wasted on a station that should have been closed, but because of political optics wasn't! That isn't a chip on a shoulder.
Good for the Borders getting a station on an arterial connection built. All about the optics. Scotland politics in a nutshell 2022.
Starmill
18 May 2012
Bolton
Indeed, both are ludicrous wastes of money with next to no benefit. Indeed there's some journey time disbenefit too because trains actually have to stop at them now.
hexagon789
2 Sep 2016
That’s long nearly 2 hours to Edinburgh! Car it is (lol)
The bus is also only every two hours ;)
And a bus, not a coach...
Also I've just realised it goes all the way to Berwick Railway Station(!), not merely Haddington.
kez19
15 May 2020
Dundee
I’m guessing this service is ran by Borders Buses? I would have thought Lothian but I’m sure I seen something when I looked up Berwick few years ago!
