Signalling - Relock & Recontrol
djp852795
27 Dec 2011
Salisbury
I'm confused about the difference (in terms of the actual work items involved) between relocking, recontrolling ... and presumably renewing/replacing an interlocking?
Anyone know of somewhere that explains these different aspects clearly (what determines when each is needed and ) - hopefully with the help of diagrams?
MarkyT
20 May 2012
Torbay
Relock means a new interlocking to control an existing track and signalling layout, with varying degrees of retention of existing trackside signalling equipment applying. It is usually carried out in conjunction with recontrol which is where the controlling signal box for the particular interlocking area is migrated to another place, usually by centralisation at one of the new ROCs. The techniques allow existing track and signalling layouts to remain, rather than the blank slate approach of full resignalling. Relock and recontrol often occurs as a precursor to more substantial layout changes. For example at Reading new interlockings and control screens at Thames Valley Signalling Centre (Didcot) took over control of the entire station area prior to the major remodelling activity, because the new platforms were built over the site of the former panel signal box and station interlocking, and because the subsequent complex multistage layout alterations were much more practical to manage with data changes in new computer based interlockings than they would have been using hardwired relay installations.
I don't know, but will take a guess just to see how close I am to understanding these things (with reference to a mechanical box). :)
  • Re-locking - Changing the interlocking sequence so that a lever move that was previously not possible is made possible (or vice versa) without changing what each lever actually does.
  • Re-controlling - Changing the function of specific levers.
  • Renewal - Replacing the physical components of the interlocking/S&C without making any changes to how it works.
So, experts, am I even close?
MarkyT
20 May 2012
Torbay
The term was and is still used to describe any change to or refurbishment of an existing mechanical frame involving the locking. A relock at one extreme might rationalise the locking, removing any redundant components and replace any worn tappets and nibs, or at the other might be a substantial layout change with reassignment of lever functions.
Railsigns
15 Feb 2010
A Relock is a replacement of an interlocking (e.g. relay interlocking to CBI) with minimal changes to the lineside infrastructure and no change to the controlling signalling centre.
A Recontrol involves migrating control of an existing interlocking from one signalling centre to another, with minimal changes to the lineside infrastructure.
A Renewal involves replacement of lineside signals and location cases etc. and mostly likely the interlocking as well.
68000
27 Jan 2008
The main problem with relocking is compliance to current standards. The relock can open up a can of worms and cost more than anticipated due to compliance requirements. Once you open up the interlocking, everyone piles in with suggested changes.
LAX54
15 Jan 2008
Manningtree / Ardleigh / Mistley was recontrolled, but simply stayed in same location, went from NX to MCS on the same Ops Floor :)
carriageline
11 Jan 2012
Cannon St was recently relocked, even though it has overlaps which are none compliant. I believe NR worked very hard to avoid having to remodel the station throat, and worked out alternative measures to bring down SPAD risks.
Sent from my iPhone using Tapatalk
