Hello for the online test they will give customer service, sequence patterns questions. when you pass the online test you will go to the assessment centre, you will two paper tests to pass the first one you will given up to 30 questions if I remember you need a B grade to pass the first test I answered up to 18 questions. To answer the questions it will be multiple choice circle answers A,B,C,D for example. Then when you pass they will ask to do another paper test they will give a sheet with train times/train staions on it and a answer sheet, then using the sheets with the train times and sheets to answers the questions like for example the train at Victora what time will get to Brixton staion.
Then after you passed that test will need to do a group exercise so with this one when I did you don't actually need to pass the actual test you need show how you work with people and how you communicate if was in a team. The final test is a role play with this one they will give you a sheet of paper with layout of a station and sheet of paper with thier polices and procedures, I can't stress this enough you need to follow the polices and procedures to the letter do not devate. The role will be in two parts dealing with a customer who is nice for the most part they will be acting as a costumer asking about what time a certain train is coming in and when it departs and asking where they can wait for it. That's all OK the sheet they provide you follow that and give good customer service be friendly, simle.
The second part will be when the customer is angry because thier train is delayed and apparently there was no notification of it begin delayed. So with this stay calm follow the sheet of paper that has the polices and procedures and explain to the customer what has happened like for example the delay was written on the notification bored located in the middle of the station and if they say I want to make a complaint you direct them where they can make the complaint and I can't do it for you but all you need at the back on the left is the complaint letters and the box is on you're right side so you can drop it in there.
