Does anyone know why Southern reformed their 171s in to three coach units? What was the point of doing this as there must be a reason behind it?
This reforming has just resulted in shorter trains and less capacity. I can not think of anything positive that has come from this.
Marshlink was always two coaches up until 2020 and then finally in 2020 it got four coaches. This was a huge improvement as this line can get very busy and two coach trains were ridiculously overcrowded. In fact even the four coach trains were not enough. I have even seen four coach trains at Rye that have been full and standing with people standing in the aisles and every available space. The worst are the peak time and school time services and also summer holiday services when Rye can get very busy. So four coach was a massive improvement but even that was not enough at certain times. But now the Marshlink has been reduced to three coach which is a big reduction in capacity and simply not enough. So this reforming has made things much worse.
Uckfield always had four coaches minimum before the reforming. You occasionally got a short formed two coach service but everything was booked four coach minimum. Even the off peak service had four coaches. Some of the peak time services even had ten coaches. Now all of the off peak services only have three coaches. So again this line has seen a big reduction in capacity. There are still some eight coach peak time trains but off peak everything is three coach and often this is not enough. Especially on the London Bridge to East Croydon section which can get very busy at all times of the day and need a bare minimum of four coaches. So again the reforming has made things worse on this line too.
So both Marshlink and Uckfield have seen a big reduction in capacity. But from what i can see this reforming seemed completely unnecessary.
The original formations until late 2022 were:
10 x two coach 171/7
6 x four coach 171/8
The new formations from late 2022 are:
4 x two coach 171/7
12 x three coach 171/8
There is also one of the four Scotrail units left but i will forget about that as i think that is going to EMR at some point soon. The other three are already gone.
So if they went back to their original formations it would seem perfectly possible to run everything as four coach minimum. Marshlink requires just three units all day. Uckfield requires just three units all day. So that is all six of the four coach units. Then you still have all ten of the two coach units available. So those two coach units can be used to extend the peak hour Uckfield services to six coach or eight coach as they are now and also for spare units too. So from what i can see the original formations would work perfectly fine and allow everything to run with four coach minimum.
I am just curious what others think of this and what exactly has been achieved by reforming in to three coach units and reducing capacity? Also is there any chance that Southern will reform them back in to their original two coach and four coach formations again?
4 x two coach 171/7
