Speed through Peterborough
GNERman
8 Oct 2008
North Yorkshire
What is the speed that a train can pass through the centre of Peterborough Station without stopping-Is this through a centre road?
Metroland
20 Jul 2005
Midlands
115mph.
But 105mph across Nene Bridge and through Fletton Curves and then across Holme Fen.
125mph north of New England and up Stoke Bank till Stoke Tunnel, and South of Holme over Leys till Offord.
heart-of-wessex
11 Jun 2005
Trowbridge
is the 140 board taken off the mainline on the New England to stoke section or do some brivers bend the rules and speed up there?
GNERman
8 Oct 2008
North Yorkshire
Do you know what it is through Doncaster and is there any other slow speeds through others south of Doncaster?
Metroland
20 Jul 2005
Midlands
Stoke bank is I think posted back down to 125mph, but I might be wrong on that. Only test trains have ever run at more, on flashing greens, which are still present, very occasionally many years ago. It was 140mph, with 135mph on Tallington curves.
All modern trains have data recorders, and any speeding (+3mph or so) would result in disciplinary action.
For a more detailed explanation some people here might have access to this:
http://www.joyce.whitchurch.btinternet.co.uk/nesa.pdf
Historically you also might be interested in this
http://www.thesectionalappendix.co.uk/
But the ruling line speeds on the fast lines of the ECML are, from memory
Kings cross to Finsbury Park
15/25/60/90/105mph
North of Hornsey it is 115mph till Langley Junction Stevenage, apart from Welywn viaduct and tunnels - 105mph
Stevenage - Offord 125mph
Offord curves 115mph
Offord to Holme 125mph
Holme fen 105mph, to Peterborough station
115, then 125mph to Stoke tunnel
115, then 105 mph Grantham
125 mph to Newark
100 mph Newark crossing
125 mph most of the rest of the way to Doncaster south, apart from Tuxford and Gamston curves and around Retford (115mph)
105 Doncaster south
125mph to York South
around 40/50 through York
Then 125mph till Tees viaduct
115mph Tees viaduct, then 125mph
115 around Darlington
Then its a mix, mostly around 105-115mph, but with lower speeds south of Durham, down to around 85ish
125 mph to Low fell
then down to 50 or lower around Newcastle.
North of Newcastle various, northward of 100mph, apart from Morpeth (50mph) and Grantshouse, which i think is around 80/90. Theres the odd stretch of 125mph.
Signalling:
Kings X - Sandy: Kings X PSB
Sandy - Stoke tunnel: Peterborough PSB
Stoke Tunnel - Shaftholme: Doncaster PSB
Shaftholme - Danby Whiske: York IECC, which also controls the Leeds area these days
Danby Whiske-South of Morpeth: Tyneside IECC
Morpeth area: Morpeth PSB
Alnwick area: Alnwick PSB
Tweedmouth PSB, around 20 miles south of Berwick to Scots border.
Scots border - South of Dundee/Falkirk including Edinburgh, is Edinburgh IECC
That's all from memory, so I'm prepared to be corrected on one or two things.
Darandio
24 Feb 2007
Might as well add something here. Didn't Durham viaduct used to be 85mph at one point? Isn't it 75 now?
Nothing is shown greater than 125mph in the sectional appendix now. Nothing is timed at greater than that either.
ungreat
11 Nov 2006
**Depends on circumstances and length of time speeding***
15/25/60/90/105mph
KX to FP is 15 leaving station,then 45 mph once halfway through Gasworks tunnel,then 60mph Copenhagen tunnel to Holloway,then 80mph to FP,then 90mph just past FP..then rises to 95mph Hornsey to north end of Wood Green Tunnel
rail-britain
12 Aug 2007
I was under the impression that the equipment for flashing green signals on that test section had been removed in about 1995, after an incident where a signaller accidentally set flashing greens for a train and it resulted in the train making an emergency stop as the driver thought it was a faulty signal!
Signallers don't "set" flashing greens! They flash if the signal ahead is green (or flashing green).
Last time I looked at the signals to see if they were flashing, they were. Which was probably a few years ago now.
If the driver didn't understand flashing greens, he/she can't have been paying attention when he/she learnt the route!
rail-britain
12 Aug 2007
During the testing period the signallers were able to set the higher line speed signals
Otherwise at all other times the standard signal patterns applied
This was so that only the Class 91 and its test train saw the flashing green signals
All drivers on the route between 1987 and 1992, when the equipment was installed, were reminded that flashing green signals may be applied and to observe them as standard green unless on the Class 91 test train where permission would apply
ungreat
11 Nov 2006
The flashing greens are now used as a "fifth aspect",and nothing more.It simply means that you have either green or flashing green as your next aspect
Ascot
26 Nov 2005
Birmingham, UK
For Peterborough, 105 south side, 125 north side.
Doncaster, 100.
York, 30. That's the fastest to get through the stations.
