No problem. Perhaps I wasn't entirely clear either. Technically St Pancras is two separate stations. The Midland side (p1-4) is entirely conventional UK colour light signalling with standard AWS and TPWS. It is controlled from West Hampstead PSB (Power Signal Box). The 'other' (HS1) side is divided into 6 long international platforms (5-10) and and 3 shorter domestics (11-13) and although functionally separate from a passenger and security point of view, the international and domestic HS1 platforms both form part of one station operationally and technically using hybrid UK/French derived interlocking and lineside signalling and French KVB warning equipment in the low speed station area. Once out of the station throat, the lineside signalling hands over to standard French TVM430 cab signalling which is also used in the Channel Tunnel and throughout the French high speed network. HS1 in it's entirety including St Pancras, is supervised by controllers in Network Rail's Ashford IECC (Integrated Electronic Control Centre). As in France, the TVM430 and KVB are part of the same signalling ecosystem. TVM is not suitable for low speed movements and KVB is not appropriate for high speed. A train is always required to initialise on KVB before being handed over to TVM and this occurs automatically at the boundary (for HS1 leaving St Pancras this occurs just as you enter the North London tunnels after passing over the ECML bridge). So it can be seen All HS1 trains in and out of St Pancras remain in 'French mode' throughout as all the trackside equipment is of that type. With no running to or from NR lines from the international station there's no need for any kind of AWS/TPWS overlay, and although notionally a dual fitted train might be able to negotiate the boundaries there is no operational need for this. Contrary to my previous statement I understand 373s have retained AWS/TPWS for working through Ashford platforms, but I understand ETCS or KVB is being fitted (alongside AWS/TPWS) through the appropriate platforms in order that 374s can call there (these new trains definitely haven't got the UK warning systems). It is thus possible that UK systems may be removed entirely from 373s as well once the Ashford work is complete. Eurostar trains of either class cannot work through the MML and ECML connection (and not just for signalling reasons).
Here's a technical paper I found about the signalling at St Pancras including a schematic diagram of the layout:
http://www.atkinsglobal.com/~/media...ignalling-at-the-st-pancras-ctrl-terminal.pdf
Note no TPWS and AWS equipment is shown in the station area itself.
