PlexiDriver
- Joined
- 5 Aug 2019
- Messages
- 204
Hey bit of a long one but thought I'd go to town
STAGE A
Opening of a train/tram style tram service from Cheltenham Spa to former St James' Square in Cheltenham. This takes into account the former alignment of the railway to St James' but also extends it to match better with the modern day realities of Cheltenham.
I've marked the two additional stations in white, Malvern Rd and Royal Wells Rd.
This would be quite easy to accomplish with very little demolishing, if any, to current infrastructure. The most expensive part would be the 560m stretch between Jessops Road (nr the Waitrose) and the terminal end Royal Well Rd.
I believe a stop at Malvern Street would be a great halfway house between the two - although it may be easier to just have a two stop shuttle between the two that provides a regular, fast, reliable link to the town centre.
Likely cost of this section: £20-25m (laying new tram track and stations being offset slightly by the ready made ground for most of the route)
STAGE B
Cheltenham Spa to... Cheltenham Spa
Again this is a rather 'easy' section to complete, although it will require more in the way of infrastructure to build. It encompasses the route from Honeybourne Way to the current heritage railway station of Cheltenham Spa. This would allow the line to run completely through the Broadway 12 miles away.
It would be supplemented by the completion of a station in Bishops Cleeve. This would give residents of the town access to a rail link to mainline Cheltenham Spa (GWR) and therefore (if Stage A was completed) access to Cheltenham town centre. It will likely cost somewhere in the region of £4-8m as it would be situated on the north side of Station Road and would be required to be wheelchair accessible.
Major parts of the process include the upgrading of the Millennium Bridge, or likely the demolition and rebuild of a new rail bridge. This is likely the reason this link hasn't already been completed and would likely see the need for central government to provide some of the funding for what would likely be a £10-15m outlay for a two track bridge replacement.
However I see this as the reason for the Staged implementation of the project. The tram project will provide a much needed income stream to help support the creation of this endeavour.
STAGE C
Broadway to Stratford-upon-Avon
This is the most complicated and fundamentally the most expensive. This would have the advantages of provided a much needed second route to the south-west of the country, that will ideally take some pressure from the mainlines.
It would be split into Stage C1 and Stage C2
Stage C1 would be run Broadway, the current terminus of the heritage railway to Honeybourne Junction, re-establishing the connection through the area. While also connected the railway to the still present rail track in the direction to Stratford-upon-Avon.
Stage C2 would follow an old alignment across and up towards Long Marston, before using a 1.04km section of new alignment to avoid a congregation of 'new' offices and company buildings.
This would then follow the old alignment which is still intact until it reaches the outskirts of Stratford-upon-Avon. Unfortunately, the hardest part of this project would be the remodelling of the road system on approach to Stratford station. A 500m stretch of road between the two roundabouts makes this a difficult project which would require the remodelling of some of the roads within Stratford. Meaning this would certainly need central funding to go ahead. Which is why the case for it would need to rest on adding an additional route and therefore making the regions lines more robust.
Once connected it would allow a new rail connection between Birmingham and Bristol and connecting areas that desperately need additional public transport. What makes it a contender in my view is the ease with which would can connect large areas of it, with only some sections such as the Honeybourne Way bridge, refurbishment of Stannells Bridge and Stratford's roundabouts being the biggest obstacles.
Overall, across a decade or so the project would likely be in the region of £70-90m, but with central government funding, grants and loans, it could be achieved in a staged way so as to make each part a self contained business case.
Let me know what you think! And a quick disclaimer that the costs are VERY rough, based on equivalent station costs, costs per km of track in similar areas, pre-existing track being "up to standard" which likely not all of it would be.
The government rejected the case in 2022, but I feel it would produce tangible benefits and allow for an increase in population that the area is already experiencing. (Also as a final side note, I don't live there!)
STAGE A
STAGE B
STAGE C
