Thalys/Eurostar connection time
williamn
22 May 2008
Would a 43 minute connection time be sufficient at Brussels do you think, coming off a Thalys which arrives at 18.08, onto the 18.51 Eurostar?
StephenHunter
22 Jul 2017
A bit of a tight one, you may have a bit of a queue at Passport Control. But should be doable.
30907
DB seem happy to offer it, and they are usually reliable on these matters. I presume you are travelling on a day when the 1850 doesn't run through from Amsterdam?
rvdborgt
24 Feb 2022
Leuven
If DB offer it, then that is because Eurostar and Thalys have included this connection time in the timetable data they sent to the European Timetable Centre (MERITS).
The gates close 30 minutes before departure time, and 15 minutes for Business Premier, so it should be doable, even with a small delay.
Mike395
23 May 2009
Bedford
Agree that it should be doable - Brussels security/customs formalities seem to, generally speaking, be the smoothest of all the Eurostar termini (I'd say that was too tight at Gare du Nord, for example). I'd not want to chance it on the last train of the day, but the 18:51 has at least one train departing after it, which Eurostar should put you on if a delay on Thalys causes the connection to be missed.
williamn
22 May 2008
Thanks all! I’m using a Brussels ticket I’ve had since the pandemic (and have changed the date in it about 5 times) hence why I’m not on the through train, and I’m actually coming from Enschede. However I’m now wondering if I should go have dinner in central Brussels and get the last train of the day instead!
riceuten
23 May 2018
Having taken this numerous times, my experience is that Eurostar were a lot more relaxed about it that Thalys were. If you miss the Eurostar, they will do their best to find you another seat or a perch seat in the corridor.
island
30 Dec 2010
If it’s a single itinerary and not the last train of the day I’d say fine.
Eurostar are pretty relaxed about this kind of thing anyway.
