Jorge Da Silva
What things were planned under the Thameslink Programme (or Thameslink 2000) that are no longer part of it. This includes services.
The destinations were a different south of the Thames.
This was one of the maps
Getting on for 10 years ago I reckon. The 2011 London and SE RUS had a thorough analysis of the entire Thameslink network and none of those destinations were on the map then.When was Guildford, Eastbourne, West Croydon and Kings Lynn dropped
No quite a few GN side stations can only take 8 and some Cambridge villages are only 4 but can use SDOIs it only the Wimbledon Loop services that drive the requirement for some 8-car units? If so, and given 12-car isn't possible, could they have gone 9-car or 10-car at least?
Ah, but that needs hindsight. When it was designed the Wimbledon Loop service wasn’t going to be running through, but would have used the bays, so there’s 4 tph less crossing conflicts straightaway. 18 tph was also supposed to run through London Bridge. So the layout would have worked completely differently (for example as with the 2011 London & SE service pairs).Also, slightly off topic, but could a different layout have been done at Blackfriars? The two bay platforms must create some congestion with conflicting movements departing needing to cross the line that heads North. I wondered if they could have created all through line platforms, using the outer faces (i.e. 1 and 4) for through services and the middle two lines (platforms 2 and 3) for terminating trains. Conflicting movements would have been removed plus you could terminate trains from the North and South, which would surely be useful in disruption or engineering works?
I took it to mean 4 tracks reducing to 2 at a north bank junction. Would have reduced the space for circulation a lot, with maybe three banks of escalators. I don’t think 4 tracking was ever a serious option.Wow, that seems a mad recipe for serious unreliability - or was there a plan to 4-track the core? Would have needed an entirely new underground tunnel.
The biggest head ache for 12 car on the gn side could well be Welwyn garden city
As even with SDO in the down direction in platform 4 a 12 coach train block access to the flyover
Plus Foxton level crossing a 12 car train would block the level crossing which block the secondary route from Royston to Cambridge. But is still a busy road
I think Blackfriars was done as it was because the Wimbledon Loop services could terminate on the west side avoiding conflict with the through trains into the Core. That obviously went out of the window when it was decided to continue running the Loop serivce through. I suspect signalling overlaps would have killed the idea of four through tracks, but "knowing then what we know now" the bays could perhaps have gone in the middle.
Given the amount of money ultimately spent on the Core, I wonder if they'd have considered a couple of flyovers or diveunders on the Blackfriars approach had they known the service pattern was going to end up as a 16tph/8tph split including the Wimbledon services.
Budget would not have allowed for that at Blackfriars and keeping the Wimbledon services into the core was as a result of local MP's Getting involved and a massive campaign in the SW postal areas.
