While having Thameslink on the Tube Map is definitely a good thing, there were a few things I wanted to point out:
1. Why do they make it look like you have to cross the river to change from TL to Circle/District at Blackfriars?
2. The connection at Farringdon to the sub-surface looks a lot longer than it is
3. They should make it clearer that Thameslink goes to St Pancras, not Kings Cross (except for a few early morning/late evening services), as it currently shows Thameslink as stopping at Kings Cross St Pancras, which is incorrect.
4. Why does the map end at Elstree/New Barnet in the north and Coulsdon South in the south. Why don't they show all stations to Luton Airport Parkway/Welwyn Garden City in the north and Gatwick in the south, just as they show the Elizabeth line all the way to Reading.
5. It should be made clear that New Southgate, Oakleigh Park, New Barnet, Petts Wood and Orpington are only served at peak hours.
Finally, there should be better communication from TfL when there is disruption on Thameslink. For example, today there are engineering works meaning that trains are running through the core. However, on TfL Go, it shows Thameslink as having a "good service".
