Thameslink vs Great Northern
lawtoni
6 May 2021
herts
Hi All,
I thought I'd start a separate thread on this subject.
Does anyone have any thoughts or opinions about the pros and cons of being a Train Driver (starting as a Trainee of course) for Thameslink vs Great Northern?
Many thanks
387star
Hi All,
Many thanks
Great Northern mainline is better work. Metro is death by moorgates and you may end up as an Overground driver
GN best depots are Kings Lynn Hitchin and certain links at Cambridge
Thameslink's best depot is Horsham with less intense night work. I'd Avoid the Bedford route for an easier life
Horizon22
Jobs & Careers
8 Sep 2019
Thameslink has a fair few metro depots too though.
Hi All,
Many thanks
Check here for all the depots and routes: https://www.railforums.co.uk/threads/different-driver-depot-route-and-traction-cards.205085/
Class2ldn
25 Feb 2011
As 387 says only decent depot on TL now is horsham who do runs on the gn side. Even three bridges work is monotonous now.
Dont touch any of the TL depots north of the river, the work is awful.
Depends what options you're looking at in terms of depots, I dont know much about the GN depots but I believe depots like kings cross, Hornsey and welwyn have a fair bit of so called metro work. Depots like Cambridge and Kings Lynn tend to have better work.
Dont forget its not all about the work, you need to factor in commuting and how you would get to work, can make a big difference aswell
Just seen in the gtr thread you've been offered welwyn or cricklewood, in terms of work I'd probably say both are fairly even in terms of work, mainly metro, cricklewood I believe is mostly sutton loops , welwyn is probably mostly moorgates so depends which one will bore you to death first lol. I'd be looking at travelling time to depots , take whatever is closer especially if one is a fair bit closer.
At this early stage I wouldn't be worrying about the work too much, you can always put in for a move if you want a change after you've passed out
lawtoni
6 May 2021
herts
Thank-you so much
yes I am likely to have a choice of TL Cricklewood or GN Welwyn
So not much to choose between them?
What about the trains? I understand that TL will be only 700 class- with the central position, better visibility is much nicer than being in the cubbyhole to the left or right?
387star
A few at three bridges kicking themselves they didn't transfer to Horsham in May 18? I was very lucky as a driver who had only been qualified jusy over a year to get the move
It was a tiny bit closer to home which helped ! I knew the work would be better given the other airport is on the Bedford side !
None of the work is ideal as it's all DOO and attractive scenery is seriously lacking in some places plus the core is like being an underground driver lol
Very intense on TL but makes you very attractive to other TOCS if you have a decent record
Class2ldn
25 Feb 2011
Plenty of three bridges drivers live in horsham and seem to prefer it for some reason, its turned into an awful depot, awful managers and drivers that don't seem to remember their job title is train driver not sicknotes lol
choochoochoo
6 Aug 2013
Welwyn has a mix of outers and inners work. They'll be going through the core at some point. They've recruited some more instructors so hopefully the training won't take ages like it has recently.
There's some uncertainty on how the work/depot will split IF the metro work goes to TfL ? Maybe seniority might play a part and those lower down may get shifted to TfL.
Class2ldn
25 Feb 2011
Yeah thinking about it welwyn is probably the better depot out the 2, better chance for a mix of work.
whoosh
3 Sep 2008
The main difference apart from routes and traction, is rostering.
Thameslink depots (that's those on the south side of the river, and also those on the Midland Main Line) have the following rest day pattern:
Sun, Mon, Tues, Late, Late, Late, Late,
{Late}, Late, Late, Wed, Thurs, Early, Early,
{Early}, Early, Early, Early, Early, Fri, Sat
Sundays above are in {brackets} and some throughout the roster will be worked on the shift shown above, whilst others will be a day off. Usually about 50% of Sundays are rostered to work throughout the roster. You have to commit to 12 per year, but you can offload your commitment to someone else if they want to and are able to take any off your hands.
This shift pattern gives less changeovers between types of shift, and gives two rest days between lates and earlies, which is easier on the body clock than other shift systems. A downside is that it's next to impossible to permanently swap for a certain shift (AMs or PMs), as one or other of you is intertwined with either the next week or previous week. I think nights is usually instead of a Late week.
You can't really swap rest days as you have the same problem of certain rest days being tied into certain shifts.
It gives a long weekend every three weeks, and you work two out of three Saturdays. Because it's the same rest day pattern repeated you'll know what your rest days are in your birthday/Christmas week in in 2022, 2023, 2024..... This is quite good for planning ahead.
The GN has a different rest day and shift pattern:
Sun Mon Tues,
{Sun} Wed, Thurs,
{Sun} Random weekday + Sat
{Sun} Fri, Sat
This is the general pattern at most GN depots (apart from Kings Lynn I think).
Shifts are AM one week and PM the next, but every so often there'll be a week of nights after which you go back to PMs the following week. (Very occasionally I have seen a roster where you might go back AMs but you'd have a long weekend between the nights and AMs).
You get a long weekend off every 4 weeks, but a lot more Saturdays off with roughly 50% worked (instead of 66.6% at TL depots).
There are about 50% of Sundays worked on the GN, with again a commitment (which you can offload) to work 12 per year. They don't pop up in the middle of a long weekend, but can appear anywhere else.
Unlike TL depots the GN rest day pattern is not fixed in stone though. It can sometimes change at a timetable change (May and December) with the December one being a particular pain as Christmas is fast approaching by the time the new roster is posted in late November.
Because the shifts change at the weekend, it can sometimes mean Lates Saturday, Sunday off, Earlies Monday, which isn't so nice on the body clock.
However, it does mean you can swap weeks with people easily. In fact quite a lot swap permanently with someone else, doing a week of their own earlies followed by a week of their swap partner's earlies and so on. Or vice versa. You'd just do your own nights when they came round - although... there's often quite a few who want to swap to those.
Swapping a rest day is easy too. If you want a Tuesday off and you are PMs just find someone else on PMs with a Tuesday rest day and see if they'll swap it for one of yours that week.
This is shift system in place on the GN at the moment. Some time ago the company did express a desire to standardise it to the Thameslink system, but as there are a significant number of drivers on the GN who permanently swap shifts, as well as other issues, nothing has been heard about it recently.
Some Welwyn drivers will route learn to Sevenoaks soon, at which point I expect the depot will be split into two links (rotas).
They currently sign 717s and 700s and have a mix of inner and outer suburban.
You may find, as alluded to another thread thread that you actually end up being offered Hornsey inner link on 717s as there is a small number on the transfer list waiting to go to Welwyn at present.
GN Boy
8 Dec 2020
England
These days, Hitchin is sadly quite 717-intense with not too much in the way of outer work.
