The Maidstone East line is rubbish.
4-SUB 4732
7 Jan 2018
Ashford to Maidstone used to be half-hourly, even if one of those only called at Bearsted en-route.
Now, in the standard hour, you have an hourly Victoria to Ashford and an hourly Charing Cross to Maidstone East.
This creates a gap in the standard quarter-hourly Victoria to Bromley South (arguably not the priority) but also causes a massive issue for connections.
The Maidstone East to Charing Cross services leave at xx:13, with the Ashford to Victoria following behind to leave at xx:27, meaning a +46 connection. In the reverse, a Victoria to Ashford leaves Maidstone at xx:00, and the Charing Cross trains will have arrived at xx:32, so a slightly better but still dire +28.
In short, this timetable is pretty garbage.
Is it fair to say the half-hourly Victoria should return?
If the xx:55 from Victoria called at all stations including Kemsing, it would arrive at Maidstone at xx:59 the following hour, and continue to Ashford. This would leave an xx:25 from Victoria, preferably calling at less stations east of Otford, to arrive at Maidstone at about xx:24 the following hour.
This would allow the Charing Cross service, arriving at Maidstone at xx:32, to continue to Ashford with a call at Bearsted only. This pattern would result, helpfully, in any Victoria / Bromley passengers being able to make a sensible connection to a Charing Cross to Ashford train just behind.
On the up, the xx:55 from Ashford, departing at xx:27 from Maidstone East, would be all stations. This would require approximately a xx:02 Maidstone East to Victoria. The only issue here would be a need for the Charing Cross to leave Maidstone at xx:54 (or close to) but a schedule clash with the Thameslink could be avoided if the Charing Cross services did not call at Swanley (I think it sets a bad precedent to have trains between Swanley and the London Bridge side of the network) or Otford.
In all, you’d probably end up with trains having layovers at Charing Cross of around 35-40 minutes, but this is achievable in the new timetable, particularly if these services move to Cannon Street in the peaks (and interwork with another service such as the Chatham fasts).
At the other end, you’d get a layover at Ashford of about 33 minutes, but in the off-peak period this would allow coaches to be attached / detached to avoid this practice at London terminals in the peak, or you could reasonably make the Charing Cross - Maidstone - Ashford fast extend to/from somewhere such as Ramsgate. The previous Victoria to Ramsgate was obviously a long drag but the Maidstone - Canterbury and Ramsgate connectivity was positive.
You could change the lengths of the layovers by amending the timetable to make the xx:25 from Victoria the slow, the xx:55 from Victoria the Maidstone, and the Charing Cross moved by 30 minutes as well. These would all work.
Anyway, there we go. The service as it is seems almost unworkable or untenable, and going hourly between Ashford and Maidstone, as well as such bad integration of the Charing Cross.
Sad Sprinter
5 Jun 2017
Way on down South London town
South of the river took a bit of a hit from Covid, we've only just got our half hourly London Bridge to Victoria service back in Southern land. Was absoloutely awful only having a half hourly train via Streatham Hill in the evenings.
The Maidstone Line does seem to be a particular punching bag for SE judging by the threads on this forum, hope it gets better.
In the peaks VIC-AFK is 2tph, on top of the 1tph CHX-MDE, but I agree off peak is not very good. I imagine the reason the CHX train does carry on to/start from Ashford is SE don't want reduced HS1 custom, given the pre-HS1 timetable had a CST-AFK service run via this route.
When it comes to passenger usage of this route, Maidstone East and West Malling stand out as the most well used stations, with 1.4m and 0.8m pre-covid respectively. Otford, Borough Green and Bearsted are around 0.4m, enough to get/have got them on semi-fasts, but all other intermediate stations are very low, struggling to get above 100k a year (Kemsing being so low it's shut on Sundays). Ashford of course is far ahead with circa 4m, but this is shared among several routes and I suspect the Maidstone East line is one of the lesser contributors.
I would suggest maybe having the Charing X train run fast from London Bridge to West Malling, then Maidstone East, Bearsted and Ashford, which is similar to the pre-HS1 service and supports the most used stations. The 2tph VIC-AFK then runs all day like before, with one all stations and one that has semi-fast running. Not sure on what the timings will look like to make it fit though. If Charing X/Cannon St is in demand for peak running, this service could double in the peak to be 2tph, with the second also calling at Swanley, Otford and Borough Green and possibly terminating at Maidstone East like now if an extension to Ashford is excessive/lacking rolling stock requirements.
Starmill
18 May 2012
Bolton
The off-peak timetable between Maidstone and Ashford is poor yes. Bearsted is also a real loser.
Unfortunately it's the same all around the country. This is is the true reality of what the cuts mean.
30907
The Maidstone route has always suffered from being relatively indirect (compared to the A20/M20) and relatively rural (except for the Maidstone area); it was always my preferred route from Bromley to Ashford, with pleasant scenery and lightly loaded trains.
I would be interested to know whether commuter traffic is recovering at the same rate as (eg) Longfield or Staplehurst, as from what I know of the area it should be prime upmarket WFH territory. I therefore very much doubt it justifies 3tph offpeak even as far as Maidstone at the moment.
Connections at Ashford are good enough, with the exception of Rye, which could be resolved by shifting the whole timetable by 30min. A second daytime tph to Ashford would be desirable from Maidstone's point of view at least, and extending the new CHX service is the obvious way. That would be my priority.
I don't see that the connections at MDE are a particular issue - is there any significant demand off-peak for CHX/WAE/LBG to Bearsted (let alone the smaller stations)? However, it would be much better if the Up CHX service could run about 15min earlier to provide an even interval at MDE. I imagine platforming at CHX would be the challenge here!
4-SUB 4732
7 Jan 2018
The least they could do is to roughly separate the service to be about 30 minutes apart at West Malling on the down, and 30 minutes apart at West Malling on the up. That way you’re not stuck at Maidstone for ages, if you miss one.
Equally, the service from Charing Cross should extend to Ashford, with just a Bearsted call. The frequency between Maidstone and Ashford is important.
As the train crew are mostly Ashford based, or possibly Tonbridge, there’s not a massive issue with going to Ashford as it gets them to a PNB point.
30907
Looking at CHX Station workings, an arrival at xx05 or so into P3 looks possible and fits through Otford Jn (at the expense of the peak VIC extras, but that's inevitable), and doesn't block P3 excessively.
Agreed.
Good point, hadn't considered that.
ComUtoR
13 Dec 2013
You shouldn't base the PNB point based on where the crew book on and off.
The journey times between London and Ashford would be very prohibitive and create imbalance with a crew diagram.
