The Micklehurst Loop again. ....
21 Feb 2018
The Micklehurst Loop – an update at the beginning of 2025
I am indebted to ‘David’ for an update on the Plevin owned railway land in Mossley. …
It is a few years since I wrote a series of articles about the Micklehurst Loop which can be found on this blog. Circumstances have since changed at what was the Plevin site. Plevin’s relocated in 2024 to another site and their yard has been gradually deteriorating since then.
Previous threads can be found on these links:
When we walked the line as exercise during COVID it was not possible to gain access to Plevin’s site. Plevin’s property was covered in the second of four substantive articles about the line.
Efini92
14 Dec 2016
Such a shame this line never reopened as part of the TRU.
Especially since NR spend a lot of money maintaining the two disused tunnels at standedge.
21 Feb 2018
Yes, and given the amount of housing in the valley now, the railway might well have paid in 21st century. Unfortunately, it is no longer practicable.
8 Feb 2021
York
Having walked through said tunnels very recently (on an organised NR/TPE walk), they are upgrading the service tunnel (closest to running line) to a very high standard in case of evacuations. The cross-passages to the live tunnel were very poor and downright unsafe, and these are getting upgraded, along with GSMR emergency phones at each cross panel among other little tidbits
Efini92
14 Dec 2016
I always wanted to walk through them. I believe there a big opening in the middle dubbed the cathedral, or something like that.
I hope they are going to fence off the shafts which lead to the canal.
AndrewE
9 Nov 2015
The cross-adits are all fenced anyway, I believe, as otherwise it gives canal people access to the railway. Some are enhanced as canal evacuation locations, and we are told this is why that rail tunnel can't be brought back into use.
8 Feb 2021
York
There is indeed, very pretty area.
Not all currently fenced, there are some sheer drops into the canal with no walkway across which are going to be fixed. You wouldn’t be able to climb out the canal onto the railway as is
Wilts Wanderer
21 Nov 2016
Maybe it’s just me, but the concept of falling through a hole in the dark into an underground canal tunnel is the stuff of nightmares an order of magnitude worse than most. o_O
billh
7 Jan 2015
The last time I looked around the area of the Uppermill end of Butterhouse, it was all filled in with no apparent access. If the other end is similar,who knows what condition it's in? The same situation pertains at Hooley Hill tunnel on the same line at Audenshaw where I think I detect a slight subsidence in the road surface of Guide Lane where it crosses the tunnel. I hope there is some means of inspecting both tunnels by means of access manholes or something?
What is the current condition of the Butterhouse tunnel between Uppermill and Diggle?
Manchester end portal is buried. Huddersfield end portal is open, with the tunnel itself being accessible apart from the buried portal. When I visited 10 years or so ago it was in reasonable condition, though the Huddersfield portal was a bit battered.
