Trackside cabinets
Paul180
3 Jan 2010
Do you mind I am from Surrey
On seeing what I thought were old cabinets I was wondering what they are for I always thought that they were for telecoms or something similar but on seeing them close up has changed that as they have a kn/m2 (kilonewtons/square meter) gauge on them I was wondering what there were for.
Similar cylindrical containers are fairly common on the DC network, I reckon they are pressurising oil filled cables.
MrGrumpy
3 Jan 2016
If it's measuring pressure wouldn't it measure in lb/sq inch?
It's in kN which suggests force so I would guess an older Wheel Impact Load Detector (for flats and the like).
Dai Corner
20 Jul 2015
It's KN / M (possibly with a 2 superscript?) so maybe it is kilonewtons per square metre (i.e. pressure)?
MrGrumpy
3 Jan 2016
Of course it is. I was scraping the bowels of my school education and forgot that it's also used to measure atmosphere/pressure.
Tio Terry
2 May 2014
Spain
Probably oil filled high voltage power distribution cables. There's a lot of them on the former Southern Region.
As I know very little about the subject could someone explain why you would fill a cable with pressurised oil?
MrGrumpy
3 Jan 2016
Take from it what you will, but Wikipedia states:
Cables for power distribution of 10 kV or higher may be insulated with oil and paper, and are run in a rigid steel pipe, semi-rigid aluminum or lead sheath. For higher voltages the oil may be kept under pressure to prevent formation of voids that would allow partial discharges within the cable insulation.
As others have said, it keeps the water out. BT (well Openreach) pressurise their main cables, though with air rather than oil.
macka
4 Oct 2012
NR uses an internal 33 kV distribution network to connect up the DC substations as they have to be situated quite close to each other to provide enough power for the 3rd rail.
Tio Terry
2 May 2014
Spain
There are still a few pressurised telecoms cables in the North ...
Really? I thought they were mainly out of use now. Do you still have 4Mhz FDM systems using them? Thought everything had changed over to PCM systems by now. I seem to remember a 4 Meg co-ax being used for PCM in amongst the London Linking Cable system, think it was Farringdon to Waterloo, that was pressurised, guess it's all long gone now!
Deepgreen
12 Jun 2013
Gomshall, Surrey
"A few remaining" and "mainly out of use" are compatible phrases.
hwl
5 Feb 2012
The 33KV cables used to supply the 3rd rail substations are XLPE insulation the older 66KV network that is being removed used pressurised oil filled cables. Still some 66KV around New Cross area but that is being /has been removed.
Paul180
3 Jan 2010
Thanks for the replys I would have never thought they would have used oil filled cables on the side of the railway. I suppose it was down to the technology of the day. Is it a bit of a headache to decommissioning and remove them these day.
Signal Head
26 May 2013
That brings back happy memories of visits to check on the temporary gas bottles (nitrogen, IIRC) put on when the pressure had dropped owing to a suspected leak. Nice easy job and a trip out. :D
Tio Terry
2 May 2014
Spain
Yes, and walking the track with a sniffer to find where the leak was! I'd like a £ for all the miles I walked.
Tio Terry
2 May 2014
Spain
An environmental nightmare! Very difficult to drain disused cables and a massive problem with the potential of oil leaks when recovering disused cables. They are often left in situ rather than risk the issues with recovery.
