Electric buses in Britain are similarly low spec to diesel buses so there is still a huge gulf in quality between British electric buses and trams. In other countries there is less of a difference.
What about the rubber tyred 'trams' in Paris, branded as T5 and T6? Enthusiasts can tell the difference between them and steel wheeled trams, but what about the general public?
how does a rubber tyred tram return the traction current?Electric buses in Britain are similarly low spec to diesel buses so there is still a huge gulf in quality between British electric buses and trams. In other countries there is less of a difference.
They're also a propriertary technology so you're tied into one supplier.The fundamental issue with these is them being non-standard, and so costly when it comes to repair or replacement.
they managed in Leeds in the 1950'sA dedicated bus lane can be very easily taken away, tram lines are a bit harder to remove.
Well yes they managed with plenty of graft elsewhere too but they removed the bus lane outside my house by painting over the signs.they managed in Leeds in the 1950's
I would guess through the metal guide rail.how does a rubber tyred tram return the traction current?
The Bombardier GLT system, an alternative to the Translohr illustrated upthread, only ever had two applications IIRC, and both have now ceased operation after not much more than 20 years. Caen had pantographs but Nancy had trolley poles, because it shared some route with conventional trolleybuses.Usually they are trolleybuses, so via the return pole. Though for those with pantographs it is likely to be the guide rail where fitted.
Bus lanes tend not to be respected by vehicles and often don’t have priority to let buses rejoin when the lane runs out. Guided bus ways are a solution but expensive to construct. I would also be curious about the reliability and range of electric buses vs a tram.
Intensive bus services chew up and rut the tarmac badly at bus stops. All that braking and acceleration energy causes real damage to the road
But that causes problems with tyre adhesion, drainage, and frost icingAnother thing those dastardly Europeans worked out years ago, with busy stops usually being concrete or even cobbled surfaces.
One idea I have seen on a forum some time ago was to use proper segregated bus routes, BRT style, with articulated electric buses as a trial for the tram business case. If demand is high enough then the tracks can be added at a future date.
I think for that to work the route would need to be marketed and branded as a new transport option and distinct from other 'normal' buses
Is there room for that in many UK cities?One idea I have seen on a forum some time ago was to use proper segregated bus routes, BRT style, with articulated electric buses as a trial for the tram business case. If demand is high enough then the tracks can be added at a future date.
I haven't seen these busways but yea the idea is as you suggest, essentially a lot of the benefits of a tram route can also be delivered with buses and a much lower start up cost. Thus easier for a council to fund. If the route becomes well used then there is a clear business case for conversion to tram which gives the additional benefits mentioned by others in this thread. Then the more contentious work (taking road space away from cars) has already been done.But that aside, isn't the Cambridge, Leigh or Gosport busway sort of what you are saying?
You can put in a tram on an existing roadway and it has to share with other traffic. But a busway denies other traffic the road space. Bit difficult in a congested arterial route with no obvious alternative.I haven't seen these busways but yea the idea is as you suggest, essentially a lot of the benefits of a tram route can also be delivered with buses and a much lower start up cost. Thus easier for a council to fund. If the route becomes well used then there is a clear business case for conversion to tram which gives the additional benefits mentioned by others in this thread. Then the more contentious work (taking road space away from cars) has already been done.
Conversely, if demand is low it might suggest the route does not warrant the cost of putting in tram tracks etc.
