Trip Report - Rye (Sussex) for Camber Sands - 2024/05/13
duffield
31 Jul 2013
East Midlands
LegFromDep.
WTT
Dep.
Real
ToArr.
WTT
Arr.
Real
DistanceIDOper CodeOriginDestinationClassCar.LoadingRef.
1Nottingham0850OTLondon St. Pancras10271026-1126m34c1B25EMNottinghamLondon St. Pancras2225Light*1
2London St. Pancras10371041+4Ashford International11141120+656m10c1J24SELondon St. PancrasMargate3956+6Medium*2
3Ashford International11241127+3Rye11461149+315m27c2D23SNAshford InternationalEastbourne1713Light*3
4Rye1548OTAshford International1610OT15m27c2D42SNEastbourneAshford International1713Medium
5Ashford International1616OTLondon St. Pancras1654OT56m10c1L47SEDover PrioryLondon St. Pancras3956+6Light*4
6London St. Pancras17051707+2Nottingham18551900+5126m34c1D61EMLondon St. PancrasNottingham2227Medium
ALLNottingham0850OTNottingham18551900+5395m62c
Notes:
*1: EMR 1st class complementaries: Cake slice not available until after 10:00!
*2: Service was delayed leaving St. Pancras due to a crossing incoming service, and lost a few minutes further before Ashford making the connection from P6 to P1 via a crowded subway somewhat marginal, however the service to Rye and Eastbourne was slightly delayed anyhow due to late boarding of a person with a wheelchair.
*3: Door on the 171 attempted to close repeatedly on the unattended wheelchair ramp. Appledore to Rye (and on to Ore) is single track with two platforms at Rye where services normally pass. Just outside Appledore station towards Rye the Dungeness power station freight line branches off to the south east. The signal box and station building at Rye are traditional and well maintained (see photos).
Rye: Its charms are well documented online, but this visit was for Camber, not Rye itself. Rye station has no toilets but there are public toilets in the car park. There is a large Jempsons supermarket opposite the station which is associated with Morrisons. It sells a huge variety of delicious looking “home made” cakes.
Camber: Stagecoach service 100 leaves from one of the bus stops just outside the station, on the hour each hour. The single fare to Camber is currently subject to the £2 cap. Return buses leave Camber Sands holiday park entrance at xx05. Real time bus tracking displays were available and appeared to be accurate.
It is an easy three mile walk from Rye station to Camber Sands, first turning left from the station entrance and leaving Rye via the A259 bridge over the river Rother then immediately turning right onto a well signposted footpath and cycleway which leads right into Camber. There are currently some diversions due to major flood bank works, but the diversions are obvious and parallel to the normal footpath; it’s necessary to cross through the flood defence works access road but this is facilitated by a “crossing guard” stationed there who opens the locked gates when necessary and safe, with no significant delay. The fields are currently full of sheep with many lambs and ewes close to the path.
Camber has high dunes towards the west end and a pleasant sand and shingle beach; facilities along the front consist of a couple of car parks, one with a beach bar and public toilets; there is another beach bar to the east. Shops are situated around the main Lydd Road a little way back from the seafront. There are no public benches along the front, but the groynes make quite good places to sit and picnic.
*4: Connection is tight at 6 minutes from P1 to P5, OK if on time. The arrival from Dover couples to the rear of 5L47 at Ashford to form a 6+6 coach train to St. Pancras. As usual it is wise to occupy the front coaches of the front unit if needing to make a short connection at St. Pancras, the front unit also is typically less crowded.
Photo: Rye Station Signal Box
Photo: Rye Station exterior
railfan99
14 Jun 2020
Victoria, Australia
Although you may not have received the slice of cake on EMR (leg 1 of your Monday trip), given 1000 to your 1027 arrival wasn't long, did you obtain any other food or drink(s) free of added charge?
Another excellent trip report. Well submitted.
duffield
31 Jul 2013
East Midlands
I just had coffee and biscuits on the way down.
Tea, juice, water, cola and a few other small snack items were available. As usual on EMR at that time of day there were hot bacon rolls, also complementary.
I had the cake on the way back, but the lemon and elderflower version was disappointingly bland, unlike the delicious bakewell pudding flavoured version I've had on previous occasions, despite both being from the same supplier. There were complementary sandwiches available on the way back but I didn't have them or pay attention to the fillings.
I've travelled with EMR to and from London quite frequently recently and the 1st complementary catering (while fairly basic compared to LNER and Avanti West Coast) is pretty consistent in terms of range and availability on weekdays. Weekend experience is spottier.
