Whats the furthest you can go from London on a TFL bus? The 405 to Redhill is the only route in the south I can think of.
405 West Croydon-RedhillSorry I should of made it clearer, I mean whats the furthest you can go outside London using a TFL bus?
Anyone know the longest route from the centre of London?
Beat me too it![]()
84 Barnet - st albans.
Do not know that one but I know the longest tfl route is the x26 from croydon to heathrow airport, in the past it used to continue toward Essex, iirc grqvesend/dartford.
113 Marble Arch to Edgware must be a contender! Edgware is probably one of the only outer suburbs in Greater London that has a regular direct bus route into Central London.Anyone know the longest route from the centre of London?
I would think that Dorking is probably the furthest outpost of any TfL routes. (As has been said, the 84 to St Albans doesn't count, as it isn't a TfL route). Tatsfield (or Passingford Bridge) may feel more remote, but in terms of distance from London they are a lot closer.
This (unofficial, and generally fairly reliable) website gives details of all bus routes in the Greater London area, including length of route to the nearest km and nearest mile
http://www.londonbusroutes.net/details.htm
(http://www.londonbusroutes.net/routes.htm clarifies more explictly which ones are not TfL)
A quick glance suggests that the X26 is indeed the longest TfL route, at 34km/21 miles. Although it is limited-stop (and the successor of a Green Line coach route, the 726),so that is, perhaps to be expected.
X68 may well be the longest daytime route from central London. The 113 to Edgware and 25 to Ilford (both of which are regular, all-day, non-express, i.e stoppng at every stop) are possibly the next longest from central London, but I'm not certain, and what exactly constitutes "central London" probably needs to be clarified before making such a statement! Although both of those kind of/almost serve a part of Oxford Street.
I wondered about the 25. What about the N8, from Oxford Circus to Hainault?Another contender would be route 25 from Tottenham Court Road (was Oxford Circus before the Crossrail upheaval) to Ilford, which is postally in Essex.
Also route 18 from Euston to Sudbury.
I do know of buses that run as far out as Harold Wood and theres a 607 to Uxbridge which is quite far out i guess. Also there is a 200 and something im sure of that runs to Basildon?![]()
Isn't the 84 a special case - its only TfL between Potters Bar and High Barnet, the rest is commercial / Hertfordshire CC? In which case the 402 Bromley to Tunbridge Wells could count - that's supported by TfL to the boundary.
The 65 was replaced by the 71 to Leatherhead, and now that;'s cut back to Chessington World of Adventures. The 65 just goes to Kingston.
The 84 is an odd one - it was an old London Transport route but when London buses was being privatised it was registered commercially rather than being tendered out - if anyone knows why I'd be interested in knowing. this does mean it's rather less frequent within London (and finishes earlier) than other similar services.
N9 Every 20 mins to LHR thats a good frequency.
It's not too bad. Of the 100+ night routes (and 24-hour routes) in London only 2 don't run at least half hourly every night. those two (N28, N31) do run half hourly at weekends and interwork so part of the routes are served half hourly all week.
IThe 84 was transferred from LT to London Country in 1982. I'm not quite sure on what basis
I was told by a neighbour who was an RT driver at Turnham Greem Garage that the 65 Ealing Broadway-Leatherhead was so long that there was just time for two trips. On the run down past Chessington Zoo he used to place a brick on the pedal to ease hise foot!
For many years the Sunday version of the 159 which was the 59 Sundays Only use to run West Hampstead to Old Coulsdon. I remember the 27 use to go from Archway Station to Teddington Station. The 14 on summer sundays use to run between Hornsey Rise and Hampton Court Palace.
Virtually every route in London is a shadow of its former self. This has more to do with the break up of London buses and the companies being based on geographical areas and the routes being only run by one garage and one company rather then 2,3 or 4 garages being spread in what would now be 2,3 04 companies.
