Vauxhall to Portsmouth & Southsea via Waterloo
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
I wonder if anybody has any idea or insight into a conundrum I am wondering about:
in the afternoon peak, when some trains out of Waterloo don't stop at Clapham Junction, for a journey from Vauxhall to somewhere further afield the fastest and easiest itinerary can be to change at Waterloo, e.g.
dep VXH 1640 arr WAT 1645
dep WAT 1700 arr PMS 1832
The fare is issued from London Terminals to Portsmouth Stations and I don't see why it shouldn't be permitted via Waterloo, but no booking engines seem to allow it. As far as they are concerned there is no doubleback, since Vauxhall isn't a timing point for the WAT-PMS train - in any case it would certainly seem to be in the spirit of station groups to allow this sort of thing anyway! As I see it this situation is quite different from getting a train to Waterloo only to change to one that stopped at Vauxhall again when passing through, which certainly wouldn't be permitted.
I can't see what rule could be used to ban it - if it is banned there are quite sparse journey opportunities from Vauxhall in the evening peak, all of them requiring two changes (at Clapham Junction and Woking).
Does anybody have any ideas how/why booking engines might be banning the above itinerary?
A slightly analogous itinerary could be this one from London Bridge to Dartford via Cannon Street, making use of the single daily train from Cannon Street that doesn't stop at London Bridge - although that is slightly different as London Bridge is a timing point in the schedule data for the non-stop CST-DFD train:
dep LBG 0737 arr CST 0743
dep CST 0754 arr DFD 0828
Strangely enough WebTIS *does* allow this one - and indeed allows other itineraries that doubleback through London Bridge and also call there, which really doesn't make sense at all. I'm quite baffled!
Bookd
27 Aug 2015
No doubt fare experts will be able to explain this, but in practical terms, if the London Terminals ticket allows entry at Vauxhall you would not need to cross the barrier line at Waterloo, and if you boarded a Portsmouth train there you would still hold a London Terminals ticket. Logically there should be no problem,but logic does not always apply to railway routings!
TEW
16 May 2008
Wouldn't be a problem in the evening peak, you can use the subway giving access to the Underground to interchange between platforms.
455driver
10 May 2010
I thought you had to pass through the gatelines before you could access the other platforms rather than there be a connection between all the platforms?
Ianno87
3 May 2015
And are there CIS screens in the subway? If not, how would one know the departure platform (other than by accessing RealTimeTrains on one's phone)?
hassaanhc
5 Jan 2014
Southall
There is definitely no shortage of screens in the subway, nor any need to pass through barriers. You don't even need to pass through barriers to get from the P1-11 side to the P12-20 side as you can walk around the back of Boots.
TEW
16 May 2008
No, the subway has shared gatelines for all platforms, you don't come to them right until you get to the entrance for the tube, a minutes walk from the platform normally.
Good luck getting between the platforms at Waterloo!
Even without the subway for are a number of narrow routes between the buffers and the backs of the various retail places. You definitely can't get all the way along from the Windsor side to the low numbers, but there are at least some links. Not exactly highlighted though...
455driver
10 May 2010
You can get all the way across, trust me although they are not meant for public use!
What happens on the Waterloo to Portsmouth train (first stop Woking or Guildford) when the ticket is examined?
I can see a long conversation taking place!
infobleep
27 Feb 2011
I'm sure there use to be one from Clapham Junction for passengers changing but I wasn't sure quiet how it worked as I couldn't get enough intineries to understand it.
I once was able to travel to Haywards Heath from Guildford via Victoria.
I got the 6.53, changed at Clapham Junction onto a train to Victoria. Then later in the day I went back to Haywards Heath from London Victoria.
I was expecting something similar to apply for services to Waterloo if I changed at Clapham Junction but I seem to think couldn't get an itinerary.
MikeWh
15 Jun 2010
Crayford
It is in the sense that Vauxhall is a member of London Terminals. Despite there being exactly how much 'terminal' about it? Confused? You should be!
I guess you're also confused about Waterloo East being a 'Terminal'.:lol:
Paul Kelly
16 Apr 2010
Reading
It's a ticket from 'London Terminals'.
Forgot that bit :oops: I thought it was from Vauxhall!
Yes indeed; that's why it's such a conundrum! I should have made the fact that Vauxhall and Waterloo are both in the "London Terminals" group a bit clearer in the OP, looking back on it.
It seems very reasonable to me, to doubleback within a station group when the second train doesn't stop at the first station, but I can't find any rule or reason that would allow it. There really don't seem to be that many situations where it offers a journey time benefit though, which is perhaps why it doesn't come up for discussion much.
paul1609
28 Jan 2006
K
I think that there are several reasons why the 16.40 example could not be shown:
the connection is exactly the minimum for Waterloo
the 16.37 southbound from Vauxhall with a same platform change at Clapham and another at Haslemere gets you to Portsmouth at the same time.
kieron
22 Mar 2012
Connah's Quay
The routeing point group station thing does not apply where the origin or destination stations are part of a group, according to page 7 of the Routeing Guide instructions. This means that Vauxhall-Portsmouth via Waterloo or Portsmouth Harbour would be right out, but Queenstown Road Battersea-Botley via Waterloo and Portsmouth Harbour is fine.
infobleep
27 Feb 2011
Could Indigo2 ask South West Trains to create an easement to allow such a journey. It may not be an issue on services before 5pm but after 5pm, I'd expect journeys via Waterloo to be quicker.
Paul Kelly
16 Apr 2010
Reading
Well it's not of personal interest to me, more of an academic interest surrounding the purpose of station fares groups (i.e. not routeing groups) and the possibilities of them. I'm not even sure it needs an easement; it's more just a matter of interpretation by booking engines. It seems quite reasonable to me, although I do note that paul1609 has pointed out that it only saves 3 minutes!
infobleep
27 Feb 2011
Well any saving seems to be music to National Rail Enquiries ears and they will offer it, even if they don't offer tickets.
