Traditional mixed trains required a goods brake (assuming that's what you mean) but it would have been unusual for the passenger coach(es) not to include a brake - most likely on those few lines where all trains ran mixed, but I can't recall seeing pictures or reports to prove it. I expect to be proved wrongQuestion says it all really - were any passenger or mixed traffic trains ever operated with a brake van in place of a brake coach (or full brake)? Happy to hear of regular timetabled examples or one-offs!
I presume they mean a goods brake van in place of a carriage with guard's van and handbrake - such as a BG or BSK etc.With respect, I think your question doesn't say it all, I think you need to clarify exactly what you mean by "brake van" versus "brake coach" or "full brake". I can't answer your question as it stands because I don't understand what you're asking, which may be my failing I accept.
I can't think of any where a good brake was used in place of a passenger brake vehicle or full brake but the Mallaig/Fort William mixed trains were usually booked Mk1 BFK-TSO for the passenger accommodation, then the goods vehicles and a goods brake van on rear.Question says it all really - were any passenger or mixed traffic trains ever operated with a brake van in place of a brake coach (or full brake)? Happy to hear of regular timetabled examples or one-offs!
Yes, thats right, thank you.I presume they mean a goods brake van in place of a carriage with guard's van and handbrake - such as a BG or BSK etc.
Ahh that's interesting, is that because the trains were split at some point subsesquently?I can't think of any where a good brake was used in place of a passenger brake vehicle or full brake but the Mallaig/Fort William mixed trains were usually booked Mk1 BFK-TSO for the passenger accommodation, then the goods vehicles and a goods brake van on rear.
I think simply because the regs required it in the 1960s/1970s. In later years, the oil tankers ran in the Mallaig mixed without a good brake van.Ahh that's interesting, is that because the trains were split at some point subsesquently?
The oil tankers had AFI (accelerated freight inshot) vacuum brakes, I'm not sure what the other traffic that existed earlier used, but the fish vans would almost certainly have been fitted as such vehicles were usually XP rated and able to be run in normal passenger trains (unless the timings didn't allow fir it) and were permitted 75mph from memory. As the entire Scottish Region was 75mph max until the early 1970s that wouldn't have been a problem though.If the goods wagons were vacuum braked they could be attached to the rear of a passenger train without problems, as used to happen with the tanks to and from Mallaig
'Titfield Thunderbolt' had saloon car (ex Upwell Tramway) and GWR brakevan. Quite possible lines like Tollesbury, Thaxted, Seahouses etc ran like that in the past?Many branch trains ran as mixed trains and in the days when not all goods wagons had automatic brakes this meant that there had to be a brake-van at the rear: this would be a goods brake. As the coaching stock in the mixed was the normal set for the branch it would contain a passenger coach with a brake compartment for when it was running as a passenger train. I have read of odd occasions where a temporary problem meant that a goods brake had to be attached to the rear of a coach or coaches that did not contain a brake compartment. However, I very much doubt if such a working would ever be planned and appear in the Carriage Working Diagrams, even for some of the odd schools and market workings that used to appear, although it is not impossible.
If the goods wagons were vacuum braked they could be attached to the rear of a passenger train without problems, as used to happen with the tanks to and from Mallaig and china clay wagons on the morning Barnstaple-Exeter. If there were several wagons at the rear of the train, it was possible (at one time) for them to be only piped ones, although they could not be at the rear.
One reason for ensuring there was a passenger brake would be that if there was no goods traffic the goods brake could be left behind (depending on other workings).I can't think of any where a good brake was used in place of a passenger brake vehicle or full brake but the Mallaig/Fort William mixed trains were usually booked Mk1 BFK-TSO for the passenger accommodation, then the goods vehicles and a goods brake van on rear.
Certainly many light railways had all trains timetabled as mixed.In the world of the first generation of light railways, I wonder if the more widespread use of brake vans across all types of train was more commonplace. How the Col Stephens empire deployed brake vans might be interesting. And what about lines like the Bishops Castle?
Yes, but the Talyllyn's was always a "passenger" brake to match the 4wh coaches. As well as its ticket window, didn't it have a bench which the locals sometimes used (ref. in Rolt, Railway Adventure)?On the Welsh narrow gauge weren't 4 wheel brake vans quite normal on passenger trains on some lines - Talyllyn for instance?
I don’t think it was necessary. The coaches were often non-corridor, so even if the guard was in the van he couldn’t get to the passengers. Employing an extra member of staff would only worsen the economics of what was often a pretty shoestring operation. Matters such as dealing with parcels, selling and collecting tickets, loading and unloading prams, etc, would be muddled through. Mixed trains often had fairly relaxed timetables and were seen as being of only local importance.Would a mixed train with unfitted goods stock have had two guards?
<pedant> bauxiteMixed trains definitely needed a brake van on the back where the goods vehicles, as most of their era, did not have continuous brakes, The Mallaig oil tankers described above, and a few others, were unusual in their era for actually having vacuum brakes, and they could make do without one behind. Milk tankers similar. But that was not the norm. If there were braked goods vehicles there was still a limit on how many there could be behind the guards' position.
The Wirral electric units that were taken to Horwich Works for heavy overhaul used to have a brake van on the back because they had air brakes whereas the steam, and early diesel, locos that hauled them were vacuum brake only, so they ran unbraked.
For those unaware, both wagons and brake vans were normally painted different colours dependent on brake. Unbraked ones, long the majority, were grey; vacuum braked ones were brown.
Many were vacuum piped (TOPS designation CAP) rather than vacuum braked - assuming all other vehicles were VB fitted (or piped if not among the rear vehicles and spaced according to the regs., and with the requisite brake force for the train as a whole) the train could still run fully fitted as the guard riding in the 'piped' BV had a vacuum brake valve to alert the driver as well as a handbrake.Unbraked ones, long the majority, were grey; vacuum braked ones were brown.
There would need to be a guard at the back if there were any unfitted wagons in the consist. The brake van would be needed if a coupling broke and the tail started running away in the wrong direction.I don’t think it was necessary. The coaches were often non-corridor, so even if the guard was in the van he couldn’t get to the passengers. Employing an extra member of staff would only worsen the economics of what was often a pretty shoestring operation. Matters such as dealing with parcels, selling and collecting tickets, loading and unloading prams, etc, would be muddled through. Mixed trains often had fairly relaxed timetables and were seen as being of only local importance.
IIRC, X.P. designated 4 wheeled non-passenger vehicles and braked freight stock which could be run as part of a passenger train. According to the 1960 General Appendix, X.P. vehicles needed oil axle boxes,automatic brakes or through pipes, screw couplings and long buffers and have a minimum tare weight of 6 tons. There seem to be a number of additional factors which had to be considered, such as length of wheelbase, piping for steam heat etc, which would have to be considered when marshalling the consist and which would restrict the maximum speed of the train. Others will know much more.An interesting subject.
I have seen "XP" mentioned quite a bit, could someone please explain what exactly it stands for / means?
Thanks,
Andy.
Some railtours were simply formed of a string of brake vans. Several pictures can be seen on the Cornwall Railway Society website.There were a few cases where a "passenger" train consisted only of a goods brake van. Usually these were at odd hours for the families of railways staff or for "workmen". There was one such working between Weymouth and Dorchester
Which may explain why my family - my parents, elder brother (aged 9) and I (6) - travelled from Georgemas Jn to Thurso in a 26-hauled goods brake van around 1963!There were a few cases where a "passenger" train consisted only of a goods brake van. Usually these were at odd hours for the families of railways staff or for "workmen". There was one such working between Weymouth and Dorchester.
On the Highland Railway, passengers could be carried in the brake van of a goods train, when there was no scheduled passenger service. Passengers wishing to do this were required to buy a first class ticket AND sign an indemnity form!
Perfectly possible, as milk tankers were vacuum braked and IIRC steam heated, and the passenger coach was the only brake accommodation on the branch AFAIK.To add a bit more fun I've seen photos of the Hemyock trains with the passenger brake at either end of the milk tankers... although milk tanks were effectively passenger stock so it didn't matter operationally other than making life interesting working out where to stop at the halts(!).
My male line comes from the Culm valley. My Gt Gt Grandad (Same surname) lived near the level crossing in Culmstock. And his father was 'removed' from Hemyock under the provisions of the then poor law. Nice to hear about the railway in my ancestral home. ThanksThe Hemyock train (which I never managed a ride in) was a challenge to put together, especially on the Up journey from Hemyock to the junction as there were milk tankers to be picked up along the way, for which it was convenient for the loco to shunt them while the coach remained at one of the platforms. You certainly find photos of the train with the solitary coach at either front or back. The passenger timetable, with just a few oddball services, didn't reflect the substantial use the line made of milk tankers, which occupied the 14xx pretty much all day and made all trains mixed. I think there were two full length milk trains left the Junction for London each day, and a range of services to and fro along the branch to bring the tankers down. The creameries along the way were substantial industrial businesses. After the end of steam passenger services (1963 I think) it still occupied a Class 03 diesel all day.
Thankyou so much for thatYou're very welcome. There's a full length illustrated article (like for many West Country branches) here on the Cornwall Railway Society website, which hopefully doesn't contradict too much of what I wrote ...
