Metro95
Which city in the UK is most likely to get a Tram/Light Rail system next? (Apart from Cardiff and Coventry which already have systems under construction.)
It grinds my gears to see endless obsessions about extending the Borders Railway, getting Okehampton to Bere Alston back up and running, 'should Oxford have a tramway', random obsessions about reopening lines in Wales that will lose money from day 1, when there's such a big elephant in the room like this.Well based on past performance it certainly wont be Leeds, despite being in clear need of one.
Coventry is not under construction. There is c20m of track at a Council Depot for wear testing.Which city in the UK is most likely to get a Tram/Light Rail system next? (Apart from Cardiff and Coventry which already have systems under construction.)
But isn't there a project called "Coventry Very Light Rail"?Coventry is not under construction. There is c20m of track at a Council Depot for wear testing.
The first route is supposed to run from the City Centre to the Hospital at Walsgrave; but there has been no consultation on the route yet so don't hold your breath.
In the UK, extensions in the West Midlands are being built:Extension under construction in Edinburgh, and a small street section for tram-trains in Cardiff with ideas of going further, both as discussed on other threads. I don't believe there an any other light rail extensions anywhere near the construction stage.
An electric bus is still a bus. It will still have all the disadvantages of a bus. Slow (even with segregated lanes, it still has to use other, congested roads), rough-riding, and low capacity. They can be easily be withdrawn without much notice or controversy, like what is happening across the UK.With electric bus technology now being what it is, do we actually need Street running trams in areas that have not already got them? I mean you can divert an electric bus in three minutes, you'd be lucky to get a diversion to a tram route up and running in three years and the emissions etc from building tram and light rail systems in the first place for this implementation will surely take far longer to compensate for then the emissions required to build and operate a fleet of electric double deckers? I suspect the next generation of urban transport will be more about finding streets that they can make buses and taxis only in order to ease congestion and smooth traffic flow
I meant brand new Tram/Light Rail systems, not extensions to existing Tram/Light Rail systems.In the UK, extensions in the West Midlands are being built:
The UK is now too impoverished to build any further light rail systems de novo. Leeds and Liverpool can dream on - Liverpool at least has Merseyrail.
- to Wolverhampton station - almost ready to open
- to Digbeth
- to Dudley and possibly Brierley Hill, subject to additional funding
Leeds does however have three former tramway corridors in the central reservations of major roads radiating from the city centre. These are currently used as guided busways, but would much better suit the green agenda if they were to be used as tramways again....although it may even be possible to combine the two modes.None of those seem to really apply to Leeds, which hasn’t got the redundant Railway corridors crying out to be converted… Leeds doesn’t have its train services split between multiple stations… Leeds has one of the best located stations to serve a city centre so no need for typical passengers to require a connecting tram service…
Yes but does it have funding? I thought it was still just a proposal.But isn't there a project called "Coventry Very Light Rail"?
I was replying to and correcting a previous post by @edwin_m that appears to have been deleted.I meant brand new Tram/Light Rail systems, not extensions to existing Tram/Light Rail systems.
I agree.Nowhere. They will talk about it for 20 years, waste millions on surveys and consultations and decide not to bother.
Yes, there is a pot of money for the Coventry VLR project at the West Midlands Combined Authority.But isn't there a project called "Coventry Very Light Rail"?
Yes, deleted because I wrote it in a hurry and I think I was confused between new networks and extensions. I intended to say there were no new networks in serious development, unless you count Coventry which is a bit different from traditional light rail.I was replying to and correcting a previous post by @edwin_m that appears to have been deleted.
However: there isn't a proposed "Leeds" system, it's a "West Yorkshire" one (apart from Calderdale, nothing happening there). The two priority routes last time I looked were Bradford-Leeds and Bradford-Dewsbury via Low Moor and Cleckheaton. One of them might not run on rails...Leeds does however have three former tramway corridors in the central reservations of major roads radiating from the city centre. These are currently used as guided busways, but would much better suit the green agenda if they were to be used as tramways again....although it may even be possible to combine the two modes.
In all fairness that is totally irrelevant.It’s easy to point to Leeds as a large place without Light Rail that therefore “deserves” a network
But look at the places that did qualify and the circumstances that they had:
Existing (but run down) local branch lines ripe to be converted to frequent trams (e.g. Manchester to Bury/ Rochdale via Oldham/ Altrincham… Croydon to Wimbledon)
Disused former railway alignments (e.g. Wolverhampton to Birmingham, the Edinburgh proposals were previously involving conversion of old railway alignment to Granton etc)
Lightly used heavy rail routes where some of the land can accommodate trams instead, even if it means squeezing the existing route down to single track (e.g. Attercliffe to Tinsley in Sheffield, Hucknall to Wilkinson Street in Nottingham - Edinburgh managed this without cutting capacity on existing lines, but still the presence of a railway-owned corridor west of Haymarket made it much easier/ cheaper to build a tram route)
Multiple “central” stations, where a frequent line between them would improve local connections (East Croydon to West Croydon, the triangle between Oic/Vic/ Deansgate in Manchester)
Poorly located “central” stations that make rail travel unattractive, but where a frequent tram into the heart of the city can make trains much more attractive (e.g. Sheffield, Nottingham)
…in short there’s no obviously easy/ urgent routes to target in Leeds, other than just directly copying existing bus services on existing roads but that’s going to be years of disruption to deliver a tram that’s stuck in the same traffic (there doesn’t seem much scope for segregated travel on a corridor like Headingley)
Good luck to any campaigns, I’m not saying that we mustn’t build a Leeds tram, but it’ll need more impetus to justify it than naked population stats - there are reasons why it’s not been a national priority
I disagree. @tbtc 's post is well argued and outlines the issues clearly.In all fairness that is totally irrelevant.
