In order :-
Class 70
Class 59
Class 60
Class 66
Class 92
Class 68
Tractive effort is where it's at...
Usually - but not always. On heavy coal trains from Liverpool Bulk Terminal, Class 60 are better than classes 59 or 66. Classes 59 & 66 seem to have adhesion problems with heavy loads on steepish gradients, especially in poor rail conditions.
The same thing happened in South Wales - the 59s experienced problemsA few years ago they sent a 59 up to Liverpool to trial it on the coal trains, it wasnt there long, the exercise hasn't been repeated and 60s are used on those trains now which answers the question.
I've always been under the impression while 59s hold the records the 60s are a more "powerful" loco.
Well firstly I would have thought that the class 68 is less powerful due to the duties it is planned to be required for - some locomotives were specifically designed for just pulling heavy loads, where as these more modern locos are expected to do more mixed duties.I'm confused as to why newer trains such as the class 68 would be less 'powerful' than older trains?
Enough trainspotters talk, these are the facts.
In order:
92 - by a very long way
70
2x 37s (put these 1 place higher if dry railhead)
60
59
56/58/66 not much between them
Bo-Bo AC locomotives (plenty of power but only 4 axles limits pulling force at the lower speeds)
37/7s next, closely followed by 47/57, then standard 37s
20s
08s/09s
At the lowest end of the scale are HST Powercars, 67s and 31s
They're mentioned half-way down that list: Collectively grouped under "Bo-Bo AC locomotives".Have to agree,it's how I'd have placed the order of running. But how about 90's and 86's?
Kind of cheating to suggest 2x class 37 isn't it?
