Why is the Class 69 not a subclass of the Class 56?
24 Mar 2019
Chester
I'm a bit puzzled as to why the Class 69 is not simply classed as a variant of the Class 56, such as a Class 56/4 or 56/9 or whatever.
I accept that the guts have been entirely replaced, new engine and controls, etc. However, this isn't the first time that a new powerplant has been put into a type without complete reclassification.
For example:
  • Class 31 - originally Mirlees, refitted with English Electric without any renumbering
  • Class 37 - units refitted with Mirlees or Ruston powerplants became the 37/9 subclass, not even consistent fitment with the subclass
  • Class 47 - 47046 refitted with a 16-cyl Ruston engine became 47/6 and subsequently the same loco became a 47/9 when fitted with a 12-cyl Ruston
The Class 69 is never going to be built in huge numbers. Does it really need a whole class to itself? It seems to me that a subclass of the 56 could have been used. Are there reasons why it wasn't? Why did it need a whole new class designation?
xotGD
4 Feb 2017
Class 31s were originally Class 30 when they had the original engine, so they were renumbered.
Class 57 became a new class.
Class 69 follows the pattern of these two.
The 37/9 and 47/6, 47/9 examples were essentially engine testbeds rather than roll-out of a 'new' locomotive fleet, so that may the rationale for the difference.
Speed43125
20 Jul 2019
Dunblane
Personally, I'd have favoured the use of a class 56 subclass purely on the basis of the relatively low number of classes left available in the locomotive category (compared with virtually all of 7xx being free for EMUs for example).
XAM2175
8 Jun 2016
They've been modified to use AAR multiple working, so there's no longer any operational compatibility with 56s.
The locomotive class numbers are taken from the vehicle numbering range, which is separate to the class numbers used for multiple units.
In any case, how many new classes of diesel locomotive are we really expecting to designate in future?
Trackman
28 Feb 2013
Lewisham
I was thinking that too.
One day something has to give with the class numbering... maybe for another thread.
adc82140
10 May 2008
The 73/9s are very much removed from their original form. But we are trying to put logic in to the TOPS system, which as we know is not really possible.
sd0733
7 Nov 2012
There arent that many free 56xxx numbers either with them being used in numbering 170 centre cars.
D365
29 Jun 2012
Because the 69s, electrically, are completely new. They’re essentially a 66-56 hybrid.
the question should be, why were the rebuilt 73s not reclassified?
Cowley
15 Apr 2016
Devon
I’d say this too actually. As @xotGD said, the 37/9s and 47/9 were test beds, but the 73/9s are heavily rebuilt (especially the Network Rail ones) and have been turned into Type 3s while running on diesel.
xotGD
4 Feb 2017
Yes, the 73/9s could legitimately have been renumbered as a new class. Class 75? Or 38? Then again they aren't all the same so do we need multiple new classes?
Cowley
15 Apr 2016
Devon
I know that we’re applying logic to a system that isn’t entirely logical here, but what about class 75 for the GBRF ones and. Actually, maybe I’ll just leave it there before my head explodes. :lol:
XAM2175
8 Jun 2016
The inverse no-logic-in-TOPS argument could apply here: the numbering standard holds that "existing electro-diesel locomotives" should be placed in Class 73 so that's exactly where they were put :p
birchesgreen
18 Aug 2015
There was some talk of renumbering the 73/9s to 75, i read somewhere. As it is the 73/9 subclass is nonsense as it contains two quite different rebuilds.
D6975
26 Nov 2009
Bristol
Why?
There are loads of class numbers available for use, far more than back in the 80s for example.
Note that preserved locos running on the mainline are all class 98s, so 40 for example is available.
norbitonflyer
24 Mar 2020
SW London
They were not renumbered when the engines were changed, as they kept their original numbers in the D5500 series. Likewise the handful of Brush Type 4s that were built with V-form engines retained their D17xx numbers when converted to standard spec.
When TOPS classes were allocated in the late 1960s, both versions still existed and were allocated different class numbers (30/31,47/48), but as the conversion programmes were completed before TOPS numbers were introduced in the early 1970s, no loco ever carried a 30xxx or 48xxx TOPS number.
A similar situation arose with the handful of NBL D61xx locos that had their MAN engines replaced by Valentas. Again both types existed when TOPS classes were introduced, classified 21 and 29, but in this case both versions were extinct before actual renumbering started.
Fairly minor engine differences have justified different TOPS classes in the past - see classes 24/25, 26/27, and 44/45, in each case the latter merely being an uprated version of the former. Other classes with different engines in otherwise similar locos include 08/10 and classes 42/43 (but not the Rolls-Royce engined class 17s)
There are counter examples of locos which did receive new D/E numbers after conversion - Gas Turbine engine 18100 was converted to straight electric and became E1000 (and later E2001). And some of the E5000 (later Class 71) Bo-Bos were converted to electro-diesels and renumbered in the E61xx series (later class 74)
071
24 Mar 2019
Chester
So it seems there is plenty of precedent for allocating a new class number. Seems a waste though when there will be very few of them built.
Trackman
28 Feb 2013
Lewisham
Why?
I thinking more of the power-rating/electric/diesel classing as originally TOPS.
As for class 89's (98's are Steam) quite a few have now reverted back to their original TOPS numbers as I assume the duplicate numbers has been removed, vehicle scrapped or whatever. I know 40145 is one as when it was renumbered they had to remind drivers of the new (well old) TOPS number.
From the RCTS website:
TOPS Class 89​
INTRODUCTION
The following numbers have been issued by the Rolling Stock Library (RSL) for privately owned diesel and electric locomotives for situations where the original TOPS number has been reused. The third digit represents the power classification and the last two digits are the final two digits of the pre-TOPS number, except where duplication occurs. The only exception is 89212 LUL 12 Sarah Siddons. Not all the preserved/privately owned locomotives are included in the series.
RSLPOOLFORMER TOPS NUMBERPRE TOPS NUMBERNOTES
89100MBDL20050D8000
89101..20001D8001Renumbered back to original TOPS number
89104MBDL01566D9504
89110MBDL20110D8110
89127..20227D8327Renumbered back to original TOPS number
89142..20142D8142Renumbered back to original TOPS number
89151MBDL..D9551Registered on TOPS March 2019
89166..20166D8166Renumbered back to original TOPS number
89188..20188D8188Renumbered back to original TOPS number
89200MBDL31018D5500
89204..26004D5304Renumbered back to original TOPS number
89210..27059D5410Renumbered back to original TOPS number
89212MBEL..12LUL Loco
89223MBDL25173D7523
89233MBDL25904D7633
89247..27001D5347Renumbered back to original TOPS number
89254MBDL24054D5054
89259MBDL25909D7659
89261MBDL24061D5061
89262MBDL25901D7612
89280..31162D5580Renumbered back to original TOPS number
89287..20087D8087Renumbered back to original TOPS number
89317MBDL..D7017
89320..7602026020De-registered
89376MBDL..D7076
89400MBEL..27000
89401MBDL47401D1500
89402..50002D402Renumbered back to original TOPS number
89403MBEL71001E5001
89404MBDL44004D4
89405..47117D1705Renumbered back to original TOPS number
89406MBDL40106D306Re-registered on TOPS April 2011
89407..50007D407Renumbered back to original TOPS number
89408..50008D408Renumbered back to original TOPS number
89408MBDL44008D8Re-registered on TOPS September 2014
89410MBDL46010D147Re-registered on TOPS May 2019
89412MBDL40012D212
89413MBDL..D1013
89415..50015D415Renumbered back to original TOPS number
89416MBDL..D1015
89417..50017D417Renumbered back to original TOPS number
89420MBDL45108D120
89421MBDL..D821
89422..50021D421Renumbered back to original TOPS number
89423MBDL45125D123
89424MBDL..D1023
89426..50026D426Renumbered back to original TOPS number
89427MBDL50027D427
89431..50031D431Renumbered back to original TOPS number
89432MBDL..D832
89433..50033D433Renumbered back to original TOPS number
89435ELRD40135D335
89437MBDL..D1010
89440MBDL45133D40
89441MBDL..D1041
89442..47192D1842Renumbered back to original TOPS number
89443MBDL50042D442
89444..50044D444Renumbered back to original TOPS number
89445..40145D345Renumbered back to original TOPS number
89448....D1048De-registered
89449..50049D449Renumbered back to original TOPS number
89453MBDL45041D53
89460MBDL45060D100
89462MBDL..D1062
89466MBDL47449D1566
89472MBDL46035D172
89500LSLS55022D9000Transferred from Pool MBDL October 2018
89501..89001..Renumbered back to original TOPS number
89502..84001E3036Renumbered back to original TOPS number
89509DBLX55009D9009
89515DBLX55015D9015
89516LSLS55016D9016Transferred from Pool MBDL October 2018
89519DBLX55019D9019
89520DBLX55002D9002
89523DBLX..DELTIC
89535..83012E3035Renumbered back to original TOPS number
89561..85101E3061Renumbered back to original TOPS number
Last updated: 18th August 2019
Ribbleman
12 Jun 2019
There are currently three different versions of Class 230 registered for use on NR. Despite the differences between them they have not received separate designations such as 230/0, 230/1 etc.
D365
29 Jun 2012
How many more diesel locomotives are you expecting to be built in the next ten years?
Taunton
1 Aug 2013
Other classes with different engines in otherwise similar locos include ... 42/43
Although they looked the same in the bodywork, the Warships from Swindon (42) and North British (43) were completely different inside, not just engines and transmissions but all the subsidiary items as well, because North British had been allowed to do their own thing. If you were cataloging spares you needed two completely different sets for the two types. Not only that, but North British designed and built a significant number of the auxiliary items themselves instead of going to established suppliers, only to go bankrupt at the end of construction. The bodywork was designed by Swindon, and the drawings sent up to Glasgow, but not the internal layout. It was rather a shame, the WR view was the best design NB did was the initial D600, then all the competent technical team saw the writing on the wall and left. There are drawings around of NB's own first pass at a Class 43 bodyshell, sort of a blend of the D600 and D6300, very sad looking at the front, which must have caused apoplexy at Swindon and an instruction to "send them ours".
Towers
30 Aug 2021
Have we had these yet?? :D
(Image shows a Network Rail Class 97, a renumbered Class 37).
Towers
30 Aug 2021
Incidentally, where do those work? I've only come across colas or drs (or herritage livery) operated test trains.
Weren't the 97s modified for ERTMS testing on the Cambrian? I think one/some of them have since made it into preservation, as I'm sure it was one of these that ran away and belted a preserved mail carriage at one of the heritage lines.
If you're talking 37s in general, pretty much anywhere on the front of NR test trains, or frequently on new/old train delivery and scrap runs at the moment!
61653 HTAFC
18 Dec 2012
The 37s numbered in the 973xx series were the ERTMS test bed, and now work infrastructure trains both on the Cambrian and elsewhere.
Going back further, many different locomotives of an assortment of classes were given 97xxx numbers when part of the BR Departmental/RTC fleet.
Another inconsistency in numbering conventions is the Network Rail 153s, which one could argue should become 953s. ;)
D365
29 Jun 2012
Indeed.
The 97s were specifically modified with Ansaldo kit, but similarly converted 37s since then (Hitachi, and soon Siemens) have not been renumbered.
