Hourly or more services only...
Xenophon PCDGS
17 Apr 2011
Southeastern to Hastings
One other rule, you can't go back on the same service you just used in the previous step.
Just to clarify matters.....This means if you go from A to B, you cannot on the next leg go back from B to A (unless the special rule about "dead-end" branch lines is brought into play).
However if there are three points on a route, A, B ,C, where B is the mid point on this leg, you can go from A to B....then carry on from B to C, as you are not going back on yourself.
I trust that this makes matters somewhat clearer.
