ScotRail don't do train to train evacuation, not in the insurance. I've asked in the past, as I was trained by another operator to do this.
train-to-train isn't done. The walkway wouldn't have handrails.Isnt there more likely hood of injury the way they did it here, by having to lower passengers off the HST, then up onto the 170? Vs if you aligned the doors and used a walkway
What was "faffy" in your book?Close the cocks, detach the errant powercarand away you go! Unless there’s damage around the couplers of course. I hate to be “one of those people”, but as always with these situations on today’s railway you wonder whether common sense solutions were put on the Too Difficult pile in favour of doing something more faffy! Anyway, all academic now!
Does SR have sufficient spare powercars (it’d be rather bizarre if they didn’t, given how many were available!) to be able to accept that this one is a scrapper, or no?
How does that work for mobility restricted passengers?train-to-train isn't done. The walkway wouldn't have handrails.
It only takes one person to wobble whilst "walking the plank" and fall off.
Deemed that transfer via the ground is the safest approach by the people that decide these things.
Can you not buy the walkways with handrails? Commonly used by TOCs in England.train-to-train isn't done. The walkway wouldn't have handrails.
Train on fire. Driver stops once off the Bridge. Fire Extinguished. Passengers removed. Train moved into yard.
Where's the faff?
The only thing that could, with hindsight, have been done better was stopping so that at least some doors were aligned with the old platforms.What was "faffy" in your book?
Where's the faff?
Indeed - too obvious! I'm staggered that SR don't/can't use train-to-train evacuation. What about incidents in tunnels, on bridges, etc., where it is often the obvious solution? The modern disintegrated railway continues to amaze. This is from Amtrak in New York - a slimmer version would suffice for emergencies.Can you not buy the walkways with handrails? Commonly used by TOCs in England.
The faff surely the time involved, nearly 4 hours to get people off the train?
There is an access point down to Riverside Drive, but only to/from the former southbound platform.The only thing that could, with hindsight, have been done better was stopping so that at least some doors were aligned with the old platforms.
Then the passengers could have been walked down through the old station as I believe it is still an access point (or at least it was during the bridge works).
As I suggested upthread, in an ideal world the crispy powercar would be detached and the passengers remain in-situ on the train, with the remaining powercar removing it to a suitable location for detraining.train-to-train isn't done. The walkway wouldn't have handrails.
Where's the faff?
Posts #1 and #5.Was it the leading or trailing power car?
Last minute platform change?Indeed - too obvious! I'm staggered that SR don't/can't use train-to-train evacuation. What about incidents in tunnels, on bridges, etc., where it is often the obvious solution? The modern disintegrated railway continues to amaze. This is from Amtrak in New York - a slimmer version would suffice for emergencies.
Yes I could have looked for myself, in fairness!Posts #1 and #5.
If the signaller had done so, I suspect s/he would have been following hallowed tradition from 28.12.1879.(Is the signal box at the other end of the bridge still manned? The signaller there may have raised the alarm).
That is not Amtrak. Looks more like Metro-North.Indeed - too obvious! I'm staggered that SR don't/can't use train-to-train evacuation. What about incidents in tunnels, on bridges, etc., where it is often the obvious solution? The modern disintegrated railway continues to amaze. This is from Amtrak in New York - a slimmer version would suffice for emergencies.
That being said, of course there may have been various obstacles in place to that approach. Was it the leading or trailing power car?
Does a Scotrail HST have outward opening passenger doors......?Could train-to-train be done with an HST having outward opening doors?
Yes.Could train-to-train be done with an HST having outward opening doors?
Ah. Been a long time since I was on one.Yes.
No.
Condition of walkway was assessed and was the third best option for the passengers. The evac to another train was option 2.The only thing that could, with hindsight, have been done better was stopping so that at least some doors were aligned with the old platforms.
Though, having said that, there's no guarantee of the condition of said platforms.
Thanks for the info!Condition of walkway was assessed and was the third best option for the passengers. The evac to another train was option 2
It would be achievable through the power car sliding doors.Could train-to-train be done with an HST having outward opening doors?
Appreciate hearing the full story, sometimes from the outside it feels like nothing is happening hence our comments!Condition of walkway was assessed and was the third best option for the passengers. The evac to another train was option 2.
Three hours into the problem was when evacuation became a reality.
0-60mins: fire brigade dealing with the fire.
61-120mins: Driver to isolate brakes and get on the move but ran into issues.
121-180mins: Fitter on site to assist and ran into further difficulties.
181-240mins: assist leaves Dundee and returns within this hour into Dundee station.
It was always "One more thing and the train can move" which always ran into further problems and wasn't as easy as envisaged. Therefore evac ordered.
When dealing with the problems - time passes by incredibly quickly!
How on earth did they end up using an evacuation bridge for passengers to board a train…?Indeed - too obvious! I'm staggered that SR don't/can't use train-to-train evacuation. What about incidents in tunnels, on bridges, etc., where it is often the obvious solution? The modern disintegrated railway continues to amaze. This is from Amtrak in New York - a slimmer version would suffice for emergencies.
This is generic and not about Scotland:The proverbial duck. Appears calm and sedate from the topside. Paddling furious underwater!
That is the Control, all day, every day.
Appears to have been a dragging brake which caused the fire, the parking brake then became jammed on preventing movement. Suspect damage will be minimal as is usually the case with brake fires.
