2E12 07:56 Victoria-Horsham
GW43125
8 Dec 2014
Evening all,
Would anyone happen to know if the service mentioned above still runs as a 455 on weekdays? I’m aware it’s booked to do so (as of December 2017), but I can’t be sure there hasn’t been a change I don’t know about.
I’m off down the south coast soon, if it’s a 455 I’ll go via Horsham, if not I’ll go straight down the mainline.
Thanks.
—I’m aware I originally put Brighton, it should read Victoria—
tsr
15 Nov 2011
Between the parallel lines
It's still booked as a single 455/8.
This service is, of course, reasonably unusual in that it runs in passenger service non-stop from Dorking to Horsham. Enjoy the "variable" track quality!
It usually runs a few minutes late, but so long as you don't try to make the 1 minute connection into the Bognor Regis service (2B02 at 0904 from Horsham), you should be fine with a booked itinerary to the Coast. Usually...!
Rumour has it that 455s might be withdrawn from the Horsham route fairly soon (but not desperately imminently), for one reason and another.
GW43125
8 Dec 2014
It’ll probably be about a month before I go so let’s hope they don’t pull it before then, I knew I had no hope on the Bognor, I’ll just get the next coastway and grab a coffee!
Thanks tsr
Southern Dvr
13 Oct 2010
May timetable looks to the when the 455s enter semi-retirement. From what I have been able to decipher from Real Time Trains the only services booked for 455s will be London Bridge-Coulsdon Town via Forest Hill, London Bridge to Caterham via Tulse Hill & London Bridge to Beckenham Junction via Crystal Palace. These are the only workings I can find timed at 75mph, all other Southern metro workings are timed for 100mph.
Thebaz
24 Nov 2016
Purley
What will happen to the 455s? Sent down to the south coast to replace 313s? Sent to Merseyside? Sent to Vic Berry's?
LA50041
20 Feb 2017
Initially theyll be used on less intensive diagrams to give less wear on aging rolling stock. Highly unlikely to head to the coast, more likely to the razor blade factory.
