tbtc
I can assure you that 158's do not work to paisley canal and have never been diagrammed to do so
I was sure I'd read on here that there have been 158s on there
benhars
Then start testing them on the Leamington Spa-Yeovil route via Oxford in order that the Co-op have suitable stock for their OA service starting next spring. 125mph should help to keep things moving whilst they are on the GW mainline... The depots should still be familiar with the stock for maintenance contracts too.
Did my eyes deceive me the other night at New St, when I saw a Voyager on a XC service to Cardiff at around 1835?
Sorry for not knowing, but what are Benhars?
I am against running new services (especially by Open Access Operators) when there is appalling overcrowding on franchised services. Sort them out first.
I know this might seem a totally radical and out there suggestion.... but how about they stay with Northern which already has depot and traincrew already familiar with them whilst also being the only franchise (opposed to OA) who uses them and is also a franchise with massive overcrowding problems...
In principle I agree with you (though I'm not prejudiced against open access operators). However, the 180 doesn't seem to be a very practical unit to use as a crowd buster. The only way I see them being helping to relieve overcrowding is if you can find a route where DMUs always run in multiple (e.g. a couple of 158s or similar), replace the 158s with one x 180 and then place the 158s where they can be used to good effect.
Two problems; 1. I can't think of a suitable route to put the 180s on, where DMUs could be freed up; and 2. the overcrowding is generally worst where units with 1/3 - 2/3 doors would be most useful to enable fast loading / unloading and they are like hen's teeth.
So, back to the Lincoln open access suggestion....
I've never heard of that or seen that beforeBenhar, it's just the colloquial term for Glasgow-Edinburgh via Shotts
Usually called "a slow coach to Edinburgh", even the Citylink coach is quicker!
Liverpool - Nottingham (run Norwich as a separate service).
a) Capacity enhancement between Liverpool - Manchester and Manchester - Sheffield which both suffer overcrowding
b) Frees up EMT 158's.
c) Means Northern do not need to give EMT their 156s in return for 150s.
That is two TOC's and two major passenger flows which benefit from self contained diagrams. One set of 2x158 might still be required to make up the number of sets required.
Yes, Lincoln gets a raw deal, but it is just utterly daft to be starting new services when overcrowding is as bad as it is elsewhere.
That's a very nice idea if it works. Would five x 180s be enough to run the service and would separating the Liverpool - Norwich free up trains, or just use more trains?
Couldn't remember if 107 was still on temporary loan to Hull Trains or not, my error.He hmm, GC have 5 180's, 101, 105, 107, 112 and 114.
The question is why should XC be allowed to 'decide' they don't want to use all their mk3 carriages when other operators are short and overcrowding isn't uncommon on XC services? DfT should issue train carriages on a 'use them or lose them' basis to prevent some operators being short while others keep them in storage.
That is most probably true, and it has been a niggling thought at the back of my mind; I have a feeling that FGW don't want the 180s back, especially when it's such a small number of trains. But recieving 5 180s or 3 HSTs, the choice SHOULD be 5 180s. I think we can conclude from both the Crosscountry and FGW arguments that what makes sense and what actually happens according to the preference of TOCs can be vastly different on the railways. The FGW idea still sounds good to me, it's just a question of whether FGW would actuallt take the 180s back. Doubtful really =/Considering FGW chose to replace 180s with HSTs I think they may prefer the GC HSTs to 180s.
[*] Avoid running up extra costs such as re-training, route clearance, re-fitting, etc, if possible
Why are people assuming that EC are going to get rid of the 180s?
Seven weekday trains in each direction had been planned for the new Lincoln/London King’s Cross services, using an additional new fleet of trains (five Adelante Class 180s). East Coast will now not introduce this new fleet, and will instead use its existing trains to operate a modified service pattern which will include a single direct service from Lincoln
DfT pointed out that the only suitable 125 mph rolling stock (which was to have been used for the Lincoln services) would be redeployed elsewhere on franchised services and would not therefore be available for use on the ECML.
Can't see them going anywhere but manchester scotland services to be honest. Can't decide if it will be right decision as 180's will be tediously slow boarding as an airport train. Does a 180 have sufficent luggage space for the high volume of suitcases.
Only question is does anyone know how much the capacity will increase and whether it would be feasible to remove a few seats for large suitcase storage?
I just don't know of another company who would get them, northern getting some extra stock ( not much net but still a gain) and TPE are in desperate need.
How will it work with the Scotland services joining and splitting? It isn't as simple as a like for like replacement.
Manchester-Scotland would be ideal and I'm convinced that's what will happen given TPE only company not to get extra stock
They could still work Manchester-scotland we're talking 5 units if needbe they could reduce First Class provision and even shorten the sets to 3 coaches so you have up to 8 3 car 180s created (8x3 is 24 and there are 25 coaches from the 5 180s if my maths is right)... the remaining coach could make one of the sets 4 car or lengthen a 180 elsewhere.. not sure if this is practical though!
