Here you go:Does anybody have any pictures of this train working from Exeter Riverside Yard as far as Yeovil Pen Mill.
Plenty of people taking pictures, I was the Driver.
Thank you
Thank you
On it again today and I'm sitting in the siding at Yeovil Pen Mill
As the driver of the infamous 'Train with no Path' (courtesy of the unjoined up railway!) I assume it was a tight fit to get in clear in the thro loop sdg at Pen Mill, unless you had split the train and then rejoined when you finally had a path at about 1720 to CC / Wx, this assumes you had same load as on Monday ie 20 empty bogie box opens ?
Only 16 yesterday. The through loop at Pen Mill is 50 SLU train was 40 SLUAs the driver of the infamous 'Train with no Path' (courtesy of the unjoined up railway!) I assume it was a tight fit to get in clear in the thro loop sdg at Pen Mill, unless you had split the train and then rejoined when you finally had a path at about 1720 to CC / Wx, this assumes you had same load as on Monday ie 20 empty bogie box opens ?
Thomas curled up fast asleep yesterday.That would be some tight fit in that loop ? I wonder if Thomas the signal box cat had overseen this shunt ......
The train does have a schedule and path, it just clashes with other trains lol.
On it again, 59005 today.
I'm sure I will be getting in the way of everything today as well.Excellent, driver
Good luck today !
