I'm genuinely surprised they don't have an overall, non-defeatable limit to 125 given that they are not allowed to run faster than that anywhere at present.
In regards to the driver not noticing the higher speed. I can also see the driver not being as conscious of the speed if they were trying to sort out an issue that had caused the speed limiter to not stay on in the first place whilst unaware that it wasn't functional. As in they knew they could attend to a problem with the TMS (being more "head in" rather than "head out" of the cab to use an aviation term) whilst knowing they had set a speed, in an area between signals and with no line speed changes they had to pay attention to but then got caught out when the ASL wasn't actually working.
I do wonder if a system like ASL is being used as a safety feature rather than a convenience should it be able to be disabled whilst the train is in motion at all? Not that it must be used but that a maximum must always be set, but that it also needs a second top limit probably the highest speed limit for the train?
Would that be a mistake in an individual train or the software for the speed limiter not being enabled when the driver put the speed set at 145 mph by mistake?
Under electric in both cases, I assume?
This however to me is the second incident in my operating area involving a IET/AT300 where issues on the TMS have led to an incident. To me this is why DAS should only back up and not replace a drivers route and traction knowledge. Personally I am horrified that the potential for DAS where the computer tells the driver what to do to the point that the driver merely follows the computer instructions was actively being promoted as a potential in a “digital railway” seminar I have attended. In this same seminar a senior manager likened the operation of the doors on a train to those found at the entrance to Morrison’s Supermarket....
Yet haven't DB been operating on the "Buchfahrplan" system (which is very similar, originally on paper but now electronic) for years without major incident?
That's right, Britain is relatively unique in that regard, expecting drivers to know the appropriate speed limit for any routing they sign with signals convey direction, rather than conveying the speed limit any turnout is subject to, as is generally the practice in Continental Europe.Isn't the German signalling system based on displaying the allowed speed for the line and any other considerations, like turnouts, though? Rather than relying on the driver's route knowledge of what speed they have to be doing in order to do something different if a change from the planned route happens due to whatever exigencies occur day to day?
The fact that a track-geometry induced derailment was unlikely doesn't mean it was in any way safe. The railway isn't built or maintained for use at 145mph and the additional stresses of operating at that speed are significantly more than the 20mph excess over the PSR might have you believe. Would have been rather nasty for the knitting to suddenly come tumbling down all over the train, for example, or for the train to derail through a set of points that disintegrated.
Was the OLE designed for 145mph? Has it been tested at 145mph in that particular location with an 802, possibly encountering a double 80x heading in the opposite direction at a closing speed of 270mph? Have the points been installed and maintained to the standards required for 145mph operation? What about the bridges, many of which will date from the original four-tracking?Various bits of the ECML were engineered for 140mph back 35 years ago.
The fact that the diesel speed record happened here and was safe probably suggests to me that this was safe.
Time to stop this silly obsession with 125 and consider properly how and where faster limits can be deployed.
Respect to this driver for proving it is possible!
Yes, line speed on the new line between Wien and St. Polten/Linz is 230km/h. I've been on RailJets that have done that speed.Do Railjet achieve 230 anywhere between Wien and Salzburg?
If anyone knows the exact date of the incident, they should be able to find timing detail here:It was some weeks ago now so the data will have dropped off of RTT. It won't have been that illuminating though I imagine as 145 versus 125 won't save that much time over a fairly short distance.
One of the arguments against conventional signalling and 140mph running is that drivers were alleged to have not had time to process a flashing green aspect. I always found it odd we didn’t run with either a GG - G - YY - Y - R pattern or a G - GY - YY - Y - R system for high speed.
Does anyone know what came of this?Some years ago, Virgin put forward a justification for raising the speed limit to 135 mph on the WCML for 390s by stating that the 125mph limit was put in place for HSTs with analogue instruments which had a tolerance on accuracy whilst, with the modern instruments on 390s, the variation was almost zero.. Thus HSTs (& class 91s?) may have been doing well over 125 routinely anyway and it can be assumed that the infrastructure was designed to take this into account.
The second option wouldn't be fail safe - if the yellow lamp failed you would get a G indication instead of a GY, so it's failed to a less restrictive aspect.One of the arguments against conventional signalling and 140mph running is that drivers were alleged to have not had time to process a flashing green aspect. I always found it odd we didn’t run with either a GG - G - YY - Y - R pattern or a G - GY - YY - Y - R system for high speed.
I highly doubt the driver intentionally risked their career and life (not to mention that of their passengers and fellow railway workers) to prove that yes, a 140mph capable train can indeed go 140mph (or a bit more).
I thought speeds over 125mph would only be allowed with some form on in-cab signalling!On a related note I see via this month's Modern Railways that 140mph is again being mooted for the York - Northallerton stretch of the ECML.
Correct.Are the IETs not future proofed with an in cab signaling system in place ready to be activated by Network Rail?
Are all Class 80x ETCS ready? Is the track infrastructure there ready to be activated.? I have not heard that it is.Correct.
Yes, I was indeed replying to a question about IETs.I think only Class 80x are ETCS ready. Is the track infrastructure there ready to be activated.? I have not heard that it is.
