waverley47
- Joined
- 17 Apr 2015
- Messages
- 658
Some (re)openings look better because there's a service you can divert/extend (and no new paths are required through bottlenecks). Alloa was helped by the fact that there were Glasgow - Stirling services that could serve Clackmannanshire (in roughly the same time that a Stirling - Dunblane - Stirling service takes). Tweedbank was just the extension of the existing Newcraighall services (no new paths required at Waverley).
But other proposals become more complicated because there's nothing "easy" to extend/divert. That's why I'm not convinced (well, that and the long distance meaning that I doubt many people would make the trip daily). Paths over Beatock already have to be carefully flighted because of the time difference between fast passenger trains and freight paths (whether or not the service actually runs, the paths are in the timetable, and long heavy freight takes a long time to get up and over from the "Clyde" to the "Annan". So you may struggle to find space over Beatock and then into Glasgow/ Edinburgh, given that there are no obvious services to extend (divert one of the two Lanark services per hour? doubt that would go down well, but what else is there, without trying to find another path into central Glasgow/ Edinburgh?)
So, slight wibble but it's relevant I promise.
Ages back we did a feasibility study for reopening stations at Beattock and Abington, with a 1tph semi fast local service picking up the stops from Carlisle to Carstairs. Timed on a 100mph emu (think class 385) it's actually very possible, with a loop somewhere. Down the hill you slot behind the TPE, and up the hill behind the Scotland via Birmingham service. (Not going to go into the calculations of service levels or actual timings). As long as your train can make it up the hill in 6.5 minutes, you can basically have your pick of paths available.
The problem comes past Carstairs. Getting a path through Haymarket both ways is virtually impossible, let alone platform capacity at Waverley.
Going to Glasgow it's even worse. You have to weave through the Glasgow suburban network, freight into Mossend, the flat junctions at Motherwell and the two track sections through cambuslang, and then platform capacity at Glasgow Central is non existent.
Basically, such a service is possible provided it serves nowhere that people want to go.
