Aberdeen - Inverness £170m Upgrade
28 Apr 2015
Thanks for the update.
Whoops! Well, in some ways this is a good thing as it will mean the station will be built with 2 platforms in one go.
Surely Network Rail must be able to pick a CAD designed station they've already built from the shelf and make a few tweaks to it, then "hey, presto" design job done. :E
You could say that the off the shelf design should be that used for Kintore. What wouldn't quite work though is that they say in the article that Dalcross was expected to cost £5m to build - Kintore's costing £12m!
takno
They tried that at Low Fell. Turned out one of the lift shafts was right on top of an old mineshaft, which is apparently a no-no because demons can just hop on the elevator up from the underworld, or maybe it's just bad architecting or something. Either way the station opened really late.
CEN60
17 Dec 2018
Platform is the "easy" bit - 2 tracking in this area - not so "easy" - plus the political hot potato of Dalcross Level Crossing (needs closed for the scheme) - but NR / RT bottled closing it in the past! Also the spectre of the need for a freight railhead at Norbord - all needs taken into account when looking at the track and signalling - so as not to preclude things in the future - however NR / TS have been dragging their heels - things were well developed for one platform 4 years ago & took a step back.
47271
28 Apr 2015
Cruising towards £30m if all that got done I'd say on the basis that it's costing £12m to put in two platforms, parking and road access at Kintore.
CEN60
17 Dec 2018
Kintore - has no track or signalling (ie it was put in by Aberdeen - Inverurie part of the project) - quite a lot of track & associated S&C / Signalling - I have no idea of the projected cost. £30m ? maybe. (the 2 high speed S&C units proposed in the feasibility- maybe upwards of £1m for starters.)
Jordan Adam
12 Sep 2017
Aberdeen
Finally got round to doing a full run from Aberdeen to Inverness and back on Tuesday. I couldn't help but notice just how uncomfortably bouncy the new tracks are between Dyce and Inverurie.
Deltic1961
30 May 2018
Not far from the new timetable being introduced.
Hopefully enough rolling stock and drivers for all these extra journeys but I don't have a good feeling about it.
Deltic1961
30 May 2018
Quite a few cancellations around Aberdeen at the moment due to lack of staff. Not looking good for the new timetable at all.
williamn
22 May 2008
Am I right in thinking that the initial section out of Aberdeen is still single track?
Altnabreac
20 Apr 2013
Salt & Vinegar
You can see the start / end of the double track in the distance of this tweet from 2018:
Dh-E1bwWkAEe1Qf
Shot is looking southwards. The houses on the left are Lamond Place while the buildings on the right are Argos and PC World in Berryden Retail Park.
The entrance to Hutcheon Street Tunnel can be seen just beyond the start / end of the single track section.
gingertom
19 Jun 2017
Kilsyth
Thanks. If it was once double, why do tunnels etc need widening?
singled for several reasons, one being to increase the loading gauge to allow larger containers to pass. To double track these tunnels and maintain loading gauge they'd need to be enlarged.
Altnabreac
20 Apr 2013
Salt & Vinegar
I'm not sure that it was actually always double.
25 inch to the mile mapping from 1926 does appear to show that it was all double tracked up until 1970 or so.
https://maps.nls.uk/view/82862604
Presumably though a combination of modern standards and increased freight clearance requirements mean that re-doubling would at the very least involve track lowering and if you wanted to meet things like W12 freight requirements and/or electrification clearances could require more significant interventions.
InOban
12 Mar 2017
Because it may have been double track, but not to the current BR structure gauge. Indeed I believe that the route to Inverness via Aberdeen is cleared to W10 at least, if not W12, because the Highland Line isn't (Killiecrankie tunnel), but others will know.
Trackbedjolly
27 May 2016
Ballast Pit siding
A really good photo of the new junction where the double track just north of Hutcheon Street starts is here https://www.railscot.co.uk/img/70/653/
As far as designs for new stations is concerned it depends to some extent on the topography and ground conditions. In these days of competitive tendering each Civil Engineering Contractor has their own Designer either in-house or uses external Consulting Engineers. They have to produce an 'economic' design which is also suitable for the existing conditions in order to win the construction contract. So, although an off-the-shelf design seems sensible it would not necessarily work for every location. Of course some of the elements are common to all stations but these may only be small items which don't affect the cost greatly.
och aye
21 Jan 2012
Update on the new station for Inverness Airport (Dalcross)
Airport rail link nears as train station plans approved
A rail link at Inverness Airport has moved a step closer after securing Highland Council’s blessing for a station.
A detailed design for a twin platform station at Dalcross is expected to follow shortly.
The council’s south area planning committee chairman Jimmy Gray discussed the proposals this week with council officers under ‘crisis procedures’ during the continuing coronavirus pandemic.
The rail station vision has been mooted for more than a decade.
A previous proposal from the regional transport agency Hitrans for a £5m rail station received planning permission three years ago. That agreement was about to expire and has now been renewed.
The latest plans include a car park for 150 vehicles, new bus stops and cycle parking.
A spokeswoman for the government agency Transport Scotland said: “The Aberdeen to Inverness rail improvement project is delivering the infrastructure to facilitate a new station at Dalcross, which is being progressed by Network Rail on behalf of Scottish ministers.
“The second platform, which will provide additional passenger and freight capacity, will be funded by the Scottish Government.”
Class 170101
1 Mar 2014
Not going to be much need for flights in the near future, perhaps as far out as 24 months, I fear.
Job Hunter
28 Feb 2017
Does anyone know what the current plans for the signal boxes at kennethmont, Huntly and Keith are?
Are they still due for closure and signalling done out of Inverness?
or has the COVID situation put a halt to this
7 Aug 2011
Insch is also, I believe, still an operational box.
On a slightly different note. Could anyone explain why the home signal at Insch (coming from Aberdeen) was changed to a coloured light vice semaphore when the Aberdeen to Inverurie dualling was conducted? As far as I know no other Insch signals were changed.
Millisle
7 Jul 2013
Lockerbie, Dumfriesshire
The Insch down home was moved 61m in the up direction as well as replaced, in connexion with the platform lengthening presumably. A new installation of obsolescent mechanical wiring, &c., was seen as less desirable, I imagine.
Idiomatically, I think one duals a road and doubles a railway.
7 Aug 2011
Doesn't that signal 'protect' the points prior to the station which, as far as I know weren't moved.
Millisle
7 Jul 2013
The signal protects the entry to the double line from its new position, presumably moved relative to the platform extension and possibly to give more distance before the level crossing, but an authoritative explanation would require a signalling engineer. Having decided to resite the signal it would make sense to replace it with an LED, which would not then have to be further replaced when Insch cabin is eventually abolished.
Job Hunter
28 Feb 2017
[/QUOTE]
This goes back to my original post, is there a date for closing these boxes?
