All Northern self-service ticket machines off line 13/7/2021
skyhigh
14 Sep 2014
Having seen the real reason for the outage - it was not an update that caused the outage, the machines have deliberately been switched off (they don't require individual visits to restore software) and there was no option for the supplier other than to turn the machines off immediately until the issue was sorted. The issue is entirely on the side of the supplier.
Dai Corner
20 Jul 2015
Not if this update has caused some problem with the network drivers or something else related.
Indeed, though I've not seen one of the broken machines in person, from the descriptions it does seem a bit like the machines are actually unable to even boot.
"If its not broken, don't fix it" comes to mind.
Or " test twice, deploy once" to paraphrase a carpenter's saying.
flitwickbeds
19 Apr 2017
...is the worst attitude when it comes to technology, and usually only spoken by those who have no real understanding of the issues being (or at least attempting to be) fixed during the change/upgrade.
DB
Guest
18 Nov 2009
Make an 'image' by setting up a machine exactly as you want it. Take a copy. Replace whatever's on each faulty machine with that copy.
Indeed, or variations such as deployment systems like Intune.
For anyone interested, Intune is a Microsoft cloudy service which deploys programs and settings onto computers - so a new computer is enrolled into Intune, and put into whichever configuration groups are needed. A clean install of Windows is then put onto the machine, and Windows will then see that it's an Intune-managed machine and allow Intune to deploy the software and settings.
Quite - the reality is you leave it alone if you can, but recognise and act quickly when that's not an option - i.e. when there's a security hole which needs patching fast.
Dai Corner
20 Jul 2015
The problem comes when your machines are so FUBAR'd your remote management system stops working.
skyhigh
14 Sep 2014
It's the complete opposite here - the machines themselves are fine (there's been no software changes to them). The management system is the issue.
flitwickbeds
19 Apr 2017
But, you also act when you WANT to as well, not just NEED to. Most of the technology we take for granted in 2021 wouldn't have happened if nobody had moved on because "it wasn't broken".
flitwickbeds
19 Apr 2017
Well... Its broken now by trying to "fix it"
Yes. The risk you take by fixing or changing anything, even tiny things. Sometimes it goes wrong, sometimes it goes catastrophically wrong. But that's no reason to never change anything, ever.
There will have been dozens/hundreds/thousands of times these machines were successfully upgraded without anyone knowing any different.
I must admit, I started using Northern's ticket machines last year and I quite like them.
py_megapixel
5 Nov 2018
Northern England
That's because either fixing it was handled incompetently, or Flowbird's systems do not facilitate testing adequately. Nothing inherently wrong with the idea of updating software.
Honestly given how poor quality the software on those machines was to start with, I'm not entirely surprised that this has happened
DB
Guest
18 Nov 2009
Yes, but you have a lot more time to plan it then, so major issues are less likely (although not, of course, impossible!)
But sometimes issues have to be fixed. I don't know what is being addressed in this case, but urgent fixes are normally due to security issues which have come to light - what you you prefer: that it's left alone because it's not "broken", and there's a major security breach as a result, or an attempt is made to fix it, with a small chance of something going wrong?
Killingworth
30 May 2018
Sheffield
The machines are switched on and humming as usual but with a totally blank screen offering quite a good mirror, see picture at 12.50. No information at the majority of stations to explain what to do if collecting tickets. It might be useful to have a permanent printed notice on or near the machines to explain what to do if out of order.
skyhigh
14 Sep 2014
No, it's not. There was an issue (not caused by a software update), that meant the only option was to take all the machines offline until it could be fixed. This isn't an issue caused by poor testing, software updates or people trying to 'fix things'.
Emyr
8 Apr 2014
An up-to-date set of infrastructure for testing, close enough to the live/production/realworld kit for testing to be meaningful, has a significant capital and operating cost. Those who forego this cost by downsizing or de-featuring the test environment aren't necessarily the ones who would bear the cost of an outage. Applies even more when a system is created or changed by a contractor chosen via competitive tendering.
A software update is an attempt to "fix things".
Vespa
20 Dec 2019
Merseyside
Of course I would like it fixed, my initial comment was tongue in cheek, it has sprung a lot of defensive responses. ;)
As I said before it should have been tested before roll out or somebody said above " Test twice, deploy once"
There is clear failure in the "fixes"
I always say "Prior Planning and Preparation Prevents Poor Performance"
py_megapixel
5 Nov 2018
Northern England
Seems we're wrong about them being completely shut down. Just passed through a Northern station now and the machine was displaying an exclamation mark accompanied by some text which was too far away to read.
I shall be alighting at another Northern station shortly and will try to upload a picture of the machine there.
DelW
15 Jan 2015
I realise that you're limited in what you can say publicly, but I take your comments as meaning that it's the central ticketing system that has been compromised, not the "outstations", I.e. the ticket machines.
On a different note, I haven't seen anyone suggesting a deliberate attack, but is that a possibility? We have heard quite a bit recently of both attempted and /or successful attacks on software systems, either by criminal or foreign power hackers. I can't see why a ticket system would be particularly a target, but the same applies to some systems which have been attacked.
py_megapixel
5 Nov 2018
Northern England
The ones I've seen today have been on and displaying the standard background image (i.e. blue with some terms and conditions in the bottom right), but instead of buttons to buy tickets there is a message stating that the machine is out of service. It advises that one tries another machine - which is unhelpful at the best of times, when the other machine, if it exists at all, could not be easy to find. But it's even worse when the other machine is also guaranteed to be out of service!
DB
Guest
18 Nov 2009
Probably a default message when it can't connect to the bac-end service.
the sniper
4 Sep 2007
Will somebody please think of the lost revenue! WE ARE ALL PAYING FOR THIS NOW!!!
<D
py_megapixel
5 Nov 2018
Northern England
Indeed, but ideally whoever wrote the default message would have considered phrasing it to encompass a scenario where the backend is at fault (and therefore none of the machines are working!)
Actually what I'd hoped would have happened is that something else would be advising people of the circumstance. Surely it can't take long for someone at Northern head office to bash out an appropriately worded sign in Word, email a PDF to the station staff, and give an instruction to print and affix a copy to each TVM? That doesn't deal with the unstaffed stations of course, but it's a start at least.
Vespa
20 Dec 2019
Merseyside
Disabling a ticket system would be disruptive to ordinary peoples lives, I wouldn't underestimate low level targets, disrupting an infrastructure would have a knock on effect beyond the immediate event such as banking, security, government staff being unable to attend work......
DB
Guest
18 Nov 2009
The machine is unlikely to be able to tell whether or not other machines are affected - and in most cases they won't be; it'll be an issue with that particular machine's network connection.
