Andy
- Joined
- 8 Sep 2005
- Messages
- 488
Hi all,
I wonder if anyone can help please? I’m currently building a small Czech layout and got to the point of signalling.
I managed to track down, some Czech signals both Home/Departure and Shunt signals (see photo), however I’m struggling to work out the pins. More specifically how to get the aspects to change.
Interestingly the shunt signals are two aspect blue/white and the home/departure signals are 4 aspect. However both come with the same 6 pins at the bottom of the signal.
If anyone could help that would be great, thank you. I’ve included a pin out from the side of the box, however all being in Czech it’s a little hard to understand.
The bottom right says white, but putting power to that line doesn’t produce a white light, I’ve managed to get the blue one activated. However not sure how signals work, does it change aspects by adding a second power line, or removing the first and swapping to the other.
Thanks again for any help.
Thanks
Andy
Thanks
Andy
