Arriva 175 outside Manchester Piccadilly?
mspljd1990
8 Jul 2016
Hi, first post here and this has no doubt been asked before. But why is it that whenever I go to Manchester Piccadilly there is always an empty Arriva Trains Wales class 175 parked outside, on the approach? It's been sat there since at least 2011.
1D53
2 Apr 2006
Not the same one all that time. Some hours in the day units that arrive in Platform 13 shunt out to wait outside the station before their next workings through Platform 14, this can be about 55 minutes on some occasions.
Harbornite
7 May 2016
Hi, it isn't the same unit. I don't know the area that well but I assume that you are referring to a siding where these units are stabled between duties.
mspljd1990
8 Jul 2016
Ah that makes sense, cheers. :) Just that literally every time I've got a train to Piccadilly there's always been one there!
Mugby
25 Nov 2012
Derby
I always think the same.
It does tend to make you wonder if it's the same one been stood there for years!
That's Mayfield Siding, and it's used for trains reversing in P13 at Piccadilly.
The FNW/ATW Chester/North Wales service has reversed there for many years, but the turnround time went up from about 25 minutes to 55 minutes several years ago, so they are parked there for longer.
More recently, ATW has been continuing some early/late services to Manchester Airport, where they have 20 minutes or so to turn round.
Since May, most off-peak services go to the Airport, leaving just the peak services to turn round at Mayfield.
It will probably all change when NR builds new platforms 15/16 at Piccadilly.
In the past, some trains have turned round at Longsight, or even Stockport.
PHILIPE
14 Nov 2011
Caerphilly
They work an hourly service from Llandudno, and due to a lay over of nearly an hour have to go to Mayfield Siding to await time to return to Llandudno. Some of them, however, go through to Manchester Airport instead of laying over.
craigybagel
25 Oct 2012
And the loco hauled services go to Longsight because at 5 MkIII + 67 they're too long for the loop.
I've seen Northern services in there occasionally too - usually late running Airport services from Southport/Liverpool that get turned around early at Piccadilly.
Stuwhu
4 Mar 2010
When this sort of thing happens, what do the driver and guard do for 55 minutes?? Read the paper?
Ianno87
3 May 2015
Yep. Or sit in a bay of 4 and have a chat. You can usually see them sat in the unit as you pass (they're effectively trapped there, as I don't believe there is any safe walking route to or from the loop)
Don't know if it counts as a break or working time on their rosters. In theory they have toilet access on the train, but they'd have to bring their own lunch/brew whatever with them beforehand.
craigybagel
25 Oct 2012
It doesn't count as a break as to be a valid PNB it has to be in an approved messroom. Whilst ATW do have access to one at Manchester Piccadilly if needs be it's a little awkward to get to on foot from Mayfield loop!
headshot119
31 Dec 2010
Dubai
Out on interest is the turn round at the airport counted as a PNB?
PHILIPE
14 Nov 2011
Caerphilly
There is no requirement for a PNB at Manchester. All trips can be accomplished between Chester and Manchester and back well within the stipulated hours without a PNB
6Gman
1 May 2012
A 20" turnround couldn't possibly be a PNB.
By the time you'd shut the unit down, walked to the messroom, walked back, and restarted the unit ... the PNB would probably be a minus figure!
:D
It's weirder than that - sometimes it transforms into a 158 or a 150!
:D
Andyh82
19 May 2014
I bet it's all drivers and conductors favourite duty then, getting paid for 55 mins doing nowt!
Johncleesefan
4 Sep 2013
I believe its a fairly common thing that happens nation wide.
Gwr services that terminate and re start in Cardiff spend 40 mins booked at the west of Cardiff usually in the brickyard siding. Again, still classed as driving time with little driving to be done once behind the signal :)
northwichcat
23 Jan 2009
Northwich
If you arrive at Piccadilly at around 18:30 on a weeknight you get a 158 sat outside Piccadilly instead of the 175 which proves it isn't always the same 175 sat there.
The timings were set up to provide extra resilience in the service, and also to position for the extension to Manchester Airport.
It meant adding another unit into the diagrams.
This way the extension costs ATW "nothing", as the resources are already in place and paid for.
Much the same thing happened to ATW Cambrian services in Birmingham when they were extended from New St to Birmingham International.
tiptoptaff
15 Feb 2013
They don't sit out there for that long, come back in for tanking and cleaning after about 15
Johncleesefan
4 Sep 2013
Thanks, I'm aware of how long they usually spend there. I'm talking about how long they can be diagrammed out there
