Arriva (Beds, Bucks, Herts)
espicer
12 Jun 2024
Luton
Press release quoted below. Sounds very much like Arriva wanted to retain the Leighton's buses contract.
They did bid for it, but Centrebus put in a better one.
Related to Arriva: Red Rose will launch a direct service to Leighton Buzzard from Aylesbury in June. That will more than likely kill off the X4 which takes the most stupid route between the two towns. 55 minutes it can take compared to a previous run of 30.
This would be good. I hate using the X4 because it is so unbelievably long-winded. I doubt it will kill off the X4, though, as a lot of school kids use it for the school in Wing, which I can never remember the name of, and Sir Henry Floyd in Aylesbury.
Isn’t there an outstation in Leighton Buzzard?
Yes, there is as far as I'm aware.
I assume the baby MMCs might move elsewhere as a result?
They will be moving elsewhere. There are no plans for them yet, though. I do see them moving to Milton Keynes, as sometimes they sneak onto the 33.
Send the MMCs to Hemel to kill off the ancient E300s (will never happen)
The E300s are slowly but surely going, dropping like flies and replaced by the Merseyside Pulsars.
I have also seen that Luton are getting 30 brand new Evoras for busway operation, with 10 being in the UK at the minute getting painted, and we are also due YJ08 EER/S/V from Telford, bringing practically the whole family of Olympuses to Luton. Still no idea what has happened to EEB though, hasn't been since it was in MK and hasn't been spotted in Luton at all. Wish we could have some E400s added into the mix though.
These Evoras are mirrorless which will be interesting to see, not a fan of the interior though from what I've heard! YJ08 EEV won't be coming to Luton, Telford spent a lot of money getting it fixed and don't want to send it away so soon, which is fair enough! And EEB is now finally tracking in Luton.
Railguy1
6 Apr 2016
Does anyone know if a freedom pass is permitted on the 724? At some point I’d like to travel from Rickmansworth or Watford to St Albans.
greenline712
2 Oct 2023
Inside the M25
It is permitted England-wide (like all other ENCTS passes), including on the 724.
Just to qualify this ... a (London) freedom pass is not valid before 0930 on Mondays-Fridays.
Hertfordshire residents have full 24/7/365 validity on their ENCTS pass in Hertfordshire ... London pass holders do not.
PeterC
29 Sep 2014
To digress a little from the original topic, can ticket machines be programmed to this level?
ACBest
30 Aug 2011
Lincoln
They can indeed - it’s very technical, but the issuing authority of each ENCTS pass can be identified by the ticket machine, and this data can then be used to reject the pass if it is used outside of the validity time of the scheme.
That can be drilled down further too - the ticket machine is also able to identify whether the pass is a disabled, disabled plus companion or elderly pass.
Finally, the validity periods can also be set differently for each individual service, which is useful in those cases where a local authority may deem a service can start accepting passes slightly before 0930.
Deerfold
26 Nov 2009
Or quite a lot earlier - In North Yorkshire they are valid on the 0715 24 from Pateley Bridge. It's not clear if that's for all card holders or just local ones.
greenline712
2 Oct 2023
Inside the M25
Almost certainly local passes only ... if the standard hours in any area are the national norm, then any easement from those norms will have an additional charge levied, probably very small.
I assume that the next 24 bus is considerably later?
