greatkingrat
- Joined
- 20 Jan 2011
- Messages
- 2,770
Applications close Friday 23rd (or earlier).
Qualified is currently 70200 and a pay offer for this year has been offered. Training rate is usually around half. I was a trainee with overground. So it's probably around 35k.Thanks for sharing this. Does anybody know the training salary and then the qualified salary for this role?
Thanks Baz, appreciate the information. How long did your training take?Qualified is currently 70200 and a pay offer for this year has been offered. Training rate is usually around half. I was a trainee with overground. So it's probably around 35k.
Don’t quote me on this but I think ARL make you retake the tests, mainly because they have extras that you have to complete and they require standard tests passed to their enhanced standards.I am currently awaiting my CBI results for another TOC and if successful I will move on to an interview. Could applying for this vacancy potentially impact that? Does anyone know?
I started in march and passed out in November. Several years ago now.Thanks Baz, appreciate the information. How long did your training take?
I passed all my tests elsewhere to enhanced. ARL didn't make me take any and put me straight to dmiDon’t quote me on this but I think ARL make you retake the tests, mainly because they have extras that you have to complete and they require standard tests passed to their enhanced standards.
If you fail any of the standard tests it could impact your current application with others.
Okay but the TOC that I'm currently awaiting my results for wouldn't just withdraw my application because I've applied for another TOCDon’t quote me on this but I think ARL make you retake the tests, mainly because they have extras that you have to complete and they require standard tests passed to their enhanced standards.
They don't know who else you have applied to.Okay but the TOC that I'm currently awaiting my results for wouldn't just withdraw my application because I've applied for another TOC
No, applying does not affect other applications little bit.Okay but the TOC that I'm currently awaiting my results for wouldn't just withdraw my application because I've applied for another TOC
Yes they do MMI believe Avanti are the only company who use CBIDoes Arriva do MMI? I have passed CBI with Avanti waiting for DMI. Don't want to risk my place at Avanti
Yes they do MMI believe Avanti are the only company who use CBIs
So its not worth applying then?Yes they do MMI believe Avanti are the only company who use CBI
Then its not worth itYou can apply but if you do the mmi it will overwrite your cbi so definitely one to think about
Is the application already close? The link above brings an error.
I'd say its worth applying see if you get to that stage and then make a decision by then you might of had a DMI if you pass great don't do the MMI if you sadly did not make it then you can do the MMI.So its not worth applying then?
I see your point thanks!I'd say its worth applying see if you get to that stage and then make a decision by then you might of had a DMI if you pass great don't do the MMI if you sadly did not make it then you can do the MMI.
What is the assessment centre process here? What are the tests?I'd say its worth applying see if you get to that stage and then make a decision by then you might of had a DMI if you pass great don't do the MMI if you sadly did not make it then you can do the MMI.
How long ago did you sit your CBI? I think a minimum of 6 months has to pass before you sit another test.Does Arriva do MMI? I have passed CBI with Avanti waiting for DMI. Don't want to risk my place at Avanti
May last monthHow long ago did you sit your CBI? I think a minimum of 6 months has to pass before you sit another test.
6 months only applies if you fail so would not apply here I believeHow long ago did you sit your CBI? I think a minimum of 6 months has to pass before you sit another test.
the same tests you have already done just they use MMI instead of CBI both are enhanced.I see your point thanks!
Are you sure? I was always under the impression that CBI/MMI are regarded as structured interviews and so the 6 month rule applies.6 months only applies if you fail so would not apply here I believe
Interesting update from the OPC that may affect other applicants too.
They are withdrawing my application because I recently sat and passed the MMI interview. You cannot sit both CBI and MMI within the same 6 month period even if you pass.
My journey for Avanti ends here. Lucky I have other irons in the fire.
Good luck to those proceeding!
Yeah no harm in throwing your hat in the ring. Nothing to lose.Not 100% sure so maybe your right but by the time they go through everything will at least a couple of months.
