Avanti West Coast Withdraws Shrewsbury Service From June 2024
Krokodil
23 Jan 2023
Wales
You do realise that the early morning peak service from Hereford towards London has been reduced from three trains down to one, don't you? And four evening arrivals is now two. Hardly suggestive of great demand there either, is it?
Yet Off Peak services are still provided. Shrewsbury didn't get any, even before the cuts.
If passenger numbers are poor on the peak Hereford services, I'm not surprised, the Anytime fares aren't quite as extortionate as the Shrewsbury ones but they're not far below £300 return.
If a government actually wanted to provide decent public transport then the fares on both lines would be reduced to sensible levels and a proper service provided. Shrewsbury has the problem that a London service duplicates the TfW class 1 services whereas if it were run as a combination of the two (so Aberystwyth to London) the Shrewsbury to London passengers would be piggybacking on the combined strength of the Shrewsbury-Birmingham passengers and the Birmingham-London passengers. A joined up and properly-funded railway would be able to make it work technically but unfortunately the siloed nature of our privatised system makes it "too difficult".
jimm
6 Apr 2012
Yes, off-peak services are still provided - and Shrewsbury had them back in the 1980s - in part because of the reason I noted about keeping the post-2019 timetable's hourly service between Paddington and Worcester balanced. If the couple of trains that go to Hereford off-peak did not do that, then the point would arrive in the course of the day when there were more IETs in Worcestershire than hourly paths back to London. What do you do then - have two trains chase each other to Oxford and London and pray that trains the other way on the single-line bits of the Cotswold Line are all bang on time?
Just because you can hook up separate services does not necessarily make it a good, or cost-effective, idea - whether it is being done by a public or privately-owned operator. I remain sceptical about the wisdom of hooking up Falmouth-Truro and Par-Newquay, with all that single line and a few loops, but that's another story.
I used to catch the 1980s Cambrian Coast Express portion to travel between Welshpool and London on occasion and the fact was that it emptied out and refilled at Shrewsbury and then again in Birmingham and vice versa. It may have been convenient for those of us making the full trip to stay in the same seat but it took three locos each way and some shunting at Shrewbury, so probably didn't ever come close to washing its face financially.
An 807 may theoretically simplify operation these days (thought would one fit on Cambrian infrastructure?), but still won't alter the underlying traffic patterns - or the post-pandemic fall-off in peak-time commuter and business travel, whatever level fares are set at. Not everyone is travelling up and down to London all the time. You might get a decent number of Shrewsbury/Telford to London passengers on a couple of direct trains on a Saturday, but probably not off-peak midweek in the winter.
Re fares - the Hereford-London anytime return (via Evesham restricted) on the direct 05.23 departure (or leaving a bit later on WMR and changing at Worcester) is £119.40. The £281 fare I presume you are looking at is any permitted route, ie allowing travel with a change at Newport.
ChrisDY10
7 Apr 2022
Kidderminster
There has been a marked rise in split ticketing (enough that I have heard announcements that make reference to them), which makes me question the numbers, too - as I would have a number whereby my tickets might be Shrewsbury-Birmingham, Birmingham-Milton Keynes, Milton Keynes-Euston - even though my journey is Shrewsbury to Euston.
Just want to add that the analysis of numbers should take in Telford and Wellington to Euston journeys, not just Shrewsbury in isolation.
even cheaper to put an additional split in at Rugby!
