AWS/TPWS integration within ETCS-equipped rolling stock
XAM2175
8 Jun 2016
TPWS can't be emulated by the ETCS display.
Is it that it can't, or just hasn't been done so far? As far as I can guess, the TPWS control logic would be contained in the ETCS Specific Transmission Module and thus the TPWS indicators could be shown on the DMI with the release buttons being emulated by the DMI's softkeys.
D365
29 Jun 2012
As far as I can tell from my datasheets - Unipart TPWSfour specifically - a modern TPWS control unit is capable of being integrated with an ETCS DMI. In this instance, the AWS/TPWS control logic remains within the Unipart FPGA (Field Programmable Gate Array) box. ”Acknowledge” buttons (AWS/TPWS and ETCS respectively) should remain as physical pushbuttons.
I’m not familiar with Thales kit, so I’m not sure how it integrates with ETCS.
JN114
28 Jun 2005
ETCS DMI certainly emulates TPWS 4 / AWS on the Heathrow Express 387s while running in “NTC” mode - at least for the indications and TPWS specific buttons (as soft keys on screen). A proper AWS plunger is still provided; and backup AWS sunflower and TPWS 4 interface are provided in the event of ETCS having to be isolated; located on the driving desk beside the DMI and above the DOO monitors respectively. The backups only function when the ETCS key switch is turned to the ISO position.
Nym
2 Mar 2007
Somewhere, not in London
ETCS can display "TPWS Four" indications, but this is not supported by several types of the ETCS implementation in the UK.
Each implementation I have seen, as @D365 says, is a retention of the TPWS FPGA with hard inputs or a datastream input either into the EVC (Main computer for ETCS) or directly to the displays. So as much as it's displaying TPWS indications including AWS, it doesn't implement AWS or TPWS.
MarkyT
20 May 2012
Torbay
ISTR they also managed to emulate TPWS/AWS properly in NTC mode, using the preferred EVC and STM (Specific Transmission Module) technique on the Siemens Class 700s for Thameslink, and presumably the GN 717s. Don't know whether back-up independent sounder, sunflower, TPWS buttons etc are provided for case of complete ETCS isolation, as described above for the Heathrow 387s.
Fragezeichnen
14 Jun 2021
Somewhere
The Thameslink units have no duplicate indicators so far as I know. Perhaps because these trains were intended to use ETCS in daily service right from the start, the situation is a bit different to something like the IET which were delivered with ETCS, to remain out of use indefinitely.
Strictly speaking, there is to my knowledge no commercially available STM for TPWS. An STM is a unit which communicates with an ETCS computer via a digital PROFIBUS interface according to the protocol defined in UNISIG Subset-035, thus minimising the amount of work needed to integrate additional national safety systems.
The TPWSfour however has simple interface consisting of various input/output pins which are turned on and off to indicate the device state, so anyone wanting to integrate it with an ETCS control unit would have to build their own hardware to interface to it and write their own STM, or integrate it via some other route.
MarkyT
20 May 2012
Torbay
Mors Smitt have a module that claims to be a STM for TPWS and AWS. If you download the pdf leaflet they cite over a thousand installations in Bombardier and Stadler units, and the ability to interface with ETCS in a number of different ways.
Nym
2 Mar 2007
That would be the TPWS unit with numerous NIRs (Notifiable Incidents) raised against it because of software configuration issues on the Class 345s, as much as close integration is a good thing, it can also cause problems as the amount of software creeps up, and starts to loose proper version control and testing.
Even for a SIL-2 (Safety Integrity Level 2, higher numbers for more 'integral' systems that can fail less), system like PPOS (Physical Prevention of OverSpeeding) (Croydon Tram) the version control and software access and levels of access available to maintainers on it is very, very limited. For TPWS (SIL-4 I believe) there should be no modification available to operators.
ComUtoR
13 Dec 2013
No physical buttons for backup but the DMI does have a built in redundancy so if the DMI failed you can swap over to the backup
XAM2175
8 Jun 2016
Thanks all. This was split out of a discussion on the new Stadler units for the Tyne and Wear Metro - it was suggested by @DanNCL that the absence of 'traditional' AWS and TPWS indicators and controls in the mock-up cab was an indication that they had been omitted from the final specification, but I'm gratified that my hunch that it could (in theory at least) all be run through ETCS and the DMI turned out to be correct.
