Barriers not accepting Oyster
rpjs
17 Nov 2015
Sleepy Hollow, New York
So, I’m sat on the 10.41 TfL Rail at Paddington where the barriers were all open but more problematically weren’t accepting touch-in from Oyster card (they all read “tickets only” and did not respond to a card touch). I asked a TfL Rail staff member who wasn’t able to help.
I guess when I get to Heathrow the barrier there will charge me the maximum fare, which should be the correct one. And if I run into any RPIs I guess I’ll be able to report back on what exactly happens if they try to PF or report someone with a foreign address!
I thought they would have directed you to use an alternative validator. In any case, if the system was down they should have a report of it so you're unlikely to receive much bother.
If you are on P5 (as RTT suggests) then your train is on a normally long distance platform that isn’t set up for Oyster. Staff should be well aware of that. It’s what the ‘tickets only’ means.
_toommm_
8 Jul 2017
If you do receive a max fare, phone them up and explain the dilemma. Other members on this forum have reported good experiences with their call centre.
rpjs
17 Nov 2015
Yes it was. I also tried the barriers at 2-3. Actually thinking about it, I think where I was trying to “touch in” on the barriers was actually a blank with no actual card reader.
Hadders
27 Apr 2011
There are some standalone barriers at Paddington but probably not near those platforms.
The chances are the system will auto-correct and assume you’ve travelled from Paddington.
cactustwirly
10 Apr 2013
The barriers on platforms 2-5 have no Oyster readers, this is because they are normally used for long distance services that don't stop in the zones (first stop Slough/Maidenhead/Reading)
Not that much more considering the touch in was attempted at a barrier without a card reader!
Well yes, put like that, but I expect it really has been quite a long term issue on Sundays, when inner suburban trains use different platforms, and staff should definitely be aware.
In a few weeks there’ll be readers and barriers on the HEx platforms as well, which conjures up the scenario where trains will be moved and PAYG charges will be wrong. Predictable but you can bet staff will be the last to work it out...
Ianno87
3 May 2015
I thought there was a standalone validator located round there somewhere? Not that I'm sure it's location is very obvious, of course!
TFN
17 Aug 2017
If a TfL or shorter distance GWR train shows up on Platforms 2-5, the procedure is to open the vehicle gate between Platform 5 & 6 and passengers using Oyster need to touch in/out at the standalone validator behind the uppercrust on the Platform 6/7 HeX entrance.
Seen it quite a few times and numerous GWR staff are on hand to ask people where they're going and to point to the reader. Unfortunately I haven't seen a TfL Rail service stop in Platforms 2-5 (other than the first 0442 and 0456 from Paddington to Heathrow), so I can't say what TfL staff do in that scenario, if they do anything at all.
MikeWh
15 Jun 2010
Crayford
Well they're going to need to change that in the next year or so!
rpjs
17 Nov 2015
Well, I've not lived in the UK for nearly eight years now, and I assumed the discs on the moulding where I guess a reader could go were readers. There was at least one other passenger as confused as I was.
jon0844
1 Feb 2009
The gateline has the ability to read smartcards, but would presumably need the relevant software update. I'm assuming they have the hardware, but even if not it would be a modular upgrade and done (in theory) in minutes. In reality, given it's the railway, it might take years.
mmh
13 Aug 2016
It doesn't have the hardware - the physical barrier is the same as one with a card reader, but instead where the card reader would be is plastic with a circular ring making it look a little like it might be one. Presumably so readers can be fitted later by removing or cutting out the plastic disc.
I can quite understand people getting confused by them. I've seen a fair few people at Victoria and London Bridge try to tap a paper magstripe ticket on the card readers - if you're unused to a system watching people ahead of you and copying them is fair enough really.
jon0844
1 Feb 2009
All the gatelines have a plain circular ring. It's just a sticker on top that shows whether it takes Oyster or a TOC-specific card! If there is the ring then I would have thought that the reader is inside. And if not, it's a very quick job to add and configure on the SKU.
In due course, Cubic will come and fit barcode readers lower down the front too if not already fitted.
K.o.R
6 Dec 2017
Try Brussels public transport (bus/tram/metro). They have paper tickets with RFID hardware inside them. Makes it impossible to rip the ticket in half when you're done, as I discovered.
Mojo
7 Aug 2005
Normally when local services are operated to/from those platforms they open up the access gates round the back of the retail booths and redirect customers to touch in/out on the standalone readers elsewhere on the station.
Parham Wood
13 Jun 2011
As a simple passenger I would expect all platforms that may have local services departing from them to have an Oyster reader. It seems a simple thing to achieve.
Mojo
7 Aug 2005
Local services do not normally depart from these platforms, they usually depart from the higher numbered platforms.
trek
30 Mar 2013
Would suspect the barriers would be left open at that time. Just hope there are no RPIs given I would doubt an irregular user would know where to find the standalone readers. Heck, most regular users don't know where they are, as I've noticed for the few peak services that use Platform 9.
And good luck if you're using the footbridge, where you have to get through the barrier, go round to the side bridge for platforms 10-14, and touch out there... All will hopefully be much easier once all platforms include Oyster...
Western Sunset
23 Dec 2014
Wimborne, Dorset
Just going back to Padd plats 2 - 5 for a moment, does that mean if I have a Zone 1 - 6 Travelcard, it won't allow me access to those particular platforms?
Just thinking if I wanted access those to take photos from the end of the platforms.
trek
30 Mar 2013
I assume you mean a paper travelcard, not one on Oyster? If on Oyster there are no readers on the barriers so definitely not, a paper shouldn't work either because a travelcard wouldn't be valid on most services from those platforms, but honestly it wouldn't surprise me that for some reason it worked anyway. Either way Paddington is pretty enthusiast friendly, if you ask you'll probably get on the platform, or be asked to sign in then be granted access anyway...
Tim R-T-C
23 May 2011
I would recommend asking if you want to get to P2-5 - otherwise you might have trouble getting back out, might look like you have travelled without a ticket from Reading etc.
I have seen spotters there before.
Personally I find Acton Mainline, Ealing Broadway, West Ealing or Hanwell to be much better for photography.
MikeWh
15 Jun 2010
Crayford
Is it? That sounds a little expensive
The single fares to/from Heathrow terminals on TfL Rail are all higher than usual zone 6 fares, but the daily cap for zones 1-6 still applies.
