Blokes avoiding the urinals and peeing all over the toilet seat instead. Is this a thing now ?
DarloRich
Fenny Stratford
Nor are they likely to if there were no cubicles to have a dump (see the China example above) but would you mind that? I think I prefer to sit down in peace if needing that :)
(admittedly the chance of "sitting down in peace" at a football ground is low :) )
honestly not bothered. If the custom where you are is to use some kind of communal latrine then so be it. I think. Once you get over the initial shock what is the issue?
BTW - the away end toilets at Bootham Crescent were a roofless brick box, with a channel cut into the floor on three sides. The flush was rain water. It was dank and green and slimy. Try a 1000 blokes all needing a half time pee after many pre match beers. Good luck having a sit down. ;)
underbank
26 Jan 2013
North West England
try going to the match and expecting privacy and a sit down
I do, every other Saturday. The bigger problem is waiting for the blokes who insist on getting into the cubicle just before half time so they can have a smoke! Happens every single game, wherever I'm sitting, so it's very widespread. You can easily smell it and see the smoke, so I can't understand how they get away with it. Everyone knows it happens. Just like it used to be in the school bogs, which were always taken over by the smokers at every break - teachers knew but ignored it.
westv
29 Mar 2013
Because the buttons never last and so your bits pop out uncomfortably, and unless you're going round wearing compression shorts all the time it's not hard to pull them aside.
Buttons? No need for buttons.
ashkeba
13 May 2019
Without buttons it's even worse. Definitely prefer the flyless version.
Without buttons, there is overlapping fabric to be pulled aside in two ways. No chance of bits escaping. Definitely better than buttons and definitely better than certain brands (ck!) which seem to both have no hole or buttons and be designed for "Action Joe" (do you know that toy in the UK?) with no space for bits.
Is the rise of holeless buttonless pants why more men now pee all over cubicles?
Clip
28 Jun 2010
Ive generally always got a bag with me and i always have a packet of baby wipes in there should i ever find this - tissue paper first then clean it with the wipes then sit down.
PeterC
29 Sep 2014
I have no problem with Y Fronts (or more usually supermarket own brand lookalikes). Easy to use at the porcelain and everything comfortably supported if you have an active lifestyle.
Cowley
15 Apr 2016
Devon
Just had a great big debate with Mrs C about Y-Fronts I didn’t realise you could still get them.
Butts
16 Jan 2011
Stirlingshire
This thread is taking the piss....big time :E
Someone upthread mentioned about zips.....
Zips and todgers are not a good combination...did anyone else as a kid have to go running to their mum with a "zipped todger"
My eyes still water at the memory of it !!
When are we going to get onto izal toilet or should I say sandpaper ..anyone remember that in the old public toilets. Used to leave more on than it took off :frown:
Arglwydd Golau
14 Apr 2011
Lordy, yes I remember that! ...embarrassing or what? And painful....remember Izal and Bronco also.
ashkeba
13 May 2019
No, was blissfully unaware until There's Something About Mary. Surely it is not a common mistake?
Cowley
15 Apr 2016
Devon
I’ve done it before. I don’t buy anything with a zip in that region these days...
Possibly one of the most harrowing experiences of my life.
Mag_seven
1 Sep 2014
here to eternity
Aye that was rough - "generation snowflake" don't know they're born. ;)
Cowley
15 Apr 2016
Devon
And that stuff would’ve made good wipe clean wallpaper...
al78
7 Jan 2013
I tend to prefer the cubicle to the urinal if it is moderately busy. I get bladder shyness if there is someone each side literally inches away meaning it takes considerable effort to release, arguably irrational but completely involuntary.
STEVIEBOY1
31 Jul 2010
I am the same, I think alot of blokes are infact.
Jona26
2 Jan 2013
West Sussex
At school we used to call Izal "John Wayne" bog roll - it's rough, tough, and takes no s**t from anyone
MidlandsChap
15 Apr 2018
What would happen if you did get started? :)
For what it's worth, I'm not sure the 'always wash your hands' thing is so clear cut: If you've just used the urinal, then presumably the only things you've touched are... yourself, and your trouser zip/buttons. However, if the toilet has taps that you have to physically touch to operate, then washing your hands means you need to handle a tap that's already been handled by - maybe, hundreds of other people since it was last cleaned. And those ones that you have to press down and which only let the water flow while you're pressing them down are even worse, as those mean you have to press firmly for several seconds, exactly where everyone else was pressing it - and continue pressing with at least one hand after you've finished washing it. I wonder whether, depending on what kinds of taps the toilet has and how careful you were when you were peeing/doing up your trousers/etc., washing your hands might actually be a lot worse for hygiene than not washing them.
100% agreed
Only wash after a dump crew checking in.
Aictos
28 Apr 2009
Just to put another slant on this...
Whatever happened to wall to floor type urinals that had a small step up so that any dribbles would be caught on porcelain (or for those too short for the cup type urinals) would end up down the drain and not pooling on the floor?
Some places still have them, rare but they do exist!
Some GN stations used to have them until some idiot decided waterless urinals were the way forward despite the obvious issues that the waterless urinals stank the toilets out more then the old ones!
