Break of journey > PAD - RDG - BRI
Dave A
7 Jun 2005
Hi all, a little help if you can please?
Next week, I'm planning on doing a journey to Bristol Temple Meads (BRI) from Paddington (PAD), but need to stop off in Reading (RDG) for a couple of hours first.
Looking at Advance fares, it looks like it will be cheaper, but I understand a "Break Of Journey" is not allowed with these ticket types.
So to save me some £££, would I be able to use a Super Off-Peak YP Return, to break my journey at RDG around 1600, then get back on at a later time?
Cheers :)
Break of journey is permitted in both directions, however, the following restriction applies from Reading:
Restriction YU said:
Tickets are valid:
On services timed to depart
Reading between 1030 and 1530,
and from 1901.
So if you were to break your journey at Reading you'd need to resume either before 1530 or after 1900.
Also the restriction from Paddington is:
Tickets are valid:
London Paddington between 1010
and 1501, and from 1901.
So the last train in the afternoon you could catch from Paddington to Reading is the 1500 (arr 1525).
Restriction YU Full Text
John @ home
1 Mar 2008
That depends on the time. This ticket has evening time restrictions from Reading. I'm on a mobile device at present, but hopefully someone will be along soon with specific details of this Restriction.
clagmonster
8 Jun 2005
Correct. Assuming you intend to leave the station at Reading, you would need separate London-Reading and Reading-Bristol tickets.
That may well be allowed, it depends on the ticket's restriction code. Please could you clarify, would it be a Bristol-London return or a London-Bristol return? Do you intend to break your journey on the outward portion, return portion or both?
Dave A
7 Jun 2005
Apologies guys, it's PAD - BRI return, and will break my journey on the outwards portion.
Ah, cheers ainsworth74. So just to clarify, if I'm on any train that leaves PAD before 1501 for RDG, and any train that departs PAD for BRI after 1901, the break of journey can be made/resumed with the Super Off-Peak ticket?
Thanks. :)
LexyBoy
23 Jan 2009
North of the rivers
Restriction code YU applies; as with most FGW flows BoJ is permitted on both outbound and return.
As others have said there are evening peak restrictions so make sure you're on a train from PAD by 1501 and leave RDG after 1900. (There is a blanket ban between these times on this ticket, unlike ex-Thames Trains flows e.g. PAD-OXF, so you can't avoid it by getting a stopping train.)
hairyhandedfool
14 Apr 2008
....So to save me some £££, would I be able to use a Super Off-Peak YP Return, to break my journey at RDG around 1600, then get back on at a later time?
Cheers :)
Monday to Friday there are restrictions.
I believe the restriction for a Super Off-Peak Return from London is 'between 1030 and 1501 and after 1901'.
I believe the Off-Peak Return restriction from London is 'between 0810 and 1640 and after 1831'.
LexyBoy
23 Jan 2009
North of the rivers
Slightly better than that - the restriction is "valid from 1901" from both Paddington and Reading, so you can take the 1911 (change at Parkway) or 1927 (direct), both of which leave Paddington before 1901.
wintonian
15 Jan 2010
Hampshire
Or for an extra £3.10 use a route; Warmster-Salsbry SVR ticket which is unrestricted out of Waterloo in the evening and is valid on trains departing Paddington as follows:
Paddington -_Depart between
0930 and 1559 (incl.), or at
1916 or later.
Bit of a long way back to Bristol though.
wintonian
15 Jan 2010
Hampshire
A £56 London - Hereford CDR route +London Evesham has restriction P7 allowing use of the Thames turbos, if it's a same day affair.
Restriction : P7
OUTWARD TRAVEL:
By any train scheduled to
arrive London Terminals or
Kensington Olympia at or after
1000.
The following exceptions
apply:
* Valid for travel from Marlow
at or late then 0830.
* Valid for travel from Bourne
End, Cookham or Furze Platt
at or later then 0840.
* Valid for travel from all
stations on the 0834 Reading
to Gatwick Airport service.
RETURN TRAVEL:
By any train except those
timed to depart London
Paddington or Waterloo before
0920, Vauxhall before 0923,
and those shown in the
table below for boarding at
London Paddington and Reading:
From From Final
Padd Rdg Destination
1600 1627 Bristol TM (BRI)
1606___1633___Penzance (PNZ)
1615___1641___Swansea (SWA)
1630___1657___Taunton (TAU)
1636___1704___Exeter St D(EXD)
1645___1711___Swansea (SWA)
1649___1720___Oxford (OXF)
1700___1726___Bristol TM (BRI)
1703___1732___Penzance (PNZ)
1715 1741___Swansea (SWA)
1722 1750 Hereford (HFD)
1730 1756 Taunton (TAU)
1733 1804 Paignton (PGN)
1745___1811___Swansea (SWA)
1748 1816 Cheltenham (CNM)
1750 1822 Worcester (WOS)
1800 1827 Bristol TM (BRI)
1803 1833 Penzance (PNZ)
1815 1841 Swansea (SWA)
1822 1850 Hereford (HFD)
1830 1856 Weston SM (WSM)
1833 1902 Exeter (EXD) FX
1833 1902 Plymouth(PLY) FO
1845 1911 Swansea (SWA)
1847 1918 Cheltenham (CNM)
1851 1922 Oxford (OXF)
1900 1927 Bristol TM (BRI)
1903 1933 Plymouth(PLY)_FX
1903 1933 Penzance(PNZ) FO
1915 1941 Swansea (SWA)
Occasionally, the departure
time or final destination of
these services may change, due
to engineering work. When
this happens, the restriction
also applies to equivalent
service.
LexyBoy
23 Jan 2009
North of the rivers
Hmm? The only CDR I can see is £44.50, restriction J9 and routed Via Evesham. Anyway, tickets routed Via Evesham wouldn't be valid via Bristol...
wintonian
15 Jan 2010
Hampshire
I ment Tonbridge and Yes Evesham is in the Cotswolds so not valid.
Didn't get much sleep last night so I'm clearly going a bit scatty now.
jkdd77
16 Nov 2008
Cheers :)
Depending on pricings, it *may* be cheaper (but less flexible) to buy an advance from BRI to RDG, a day single (or return, if returning the same day) from RDG to PAD, and an advance from PAD to BRI (or RDG, if returning the same day).
wintonian
15 Jan 2010
Hampshire
Doing it that way I would invest in a Thames Branches Day Ranger for £16.40 to cover RDG - PAD
