Brighton to Manchester route?
etr221
10 Mar 2018
I didn’t know there was a direct WLL - GWML connection? Was this the one that is today a turnback with a small platform?
It ran through what became the Eurostar depot (whatever it is now) - the link off the WLL was Eurostar's main access route into the depot.
The GWR was a partner in the West London Joint Railway, in order to gain access to the Thames. Originally the WLR crossed the GWR on the level...
hexagon789
2 Sep 2016
1984/5 PA WTT air-con workings show as
1E54 06:54 Paddington-Hull
1M88 06:25 Poole-Manchester
1S39 07:34 Poole-Glasgow
1M50 08:50 Brighton-Manchester
1E63 09:40 Poole-Newcastle
1M07 12:54 Brighton-Manchester
1E13 14:13 Portsmouth-York
1M23 14:40 Poole-Liverpool
1M40 17:05 Poole-Liverpool
1M41 18:48 Brighton-Derby
1O03 06:50 Liverpool-Poole
1O27 06:45 York-Portsmouth
1O15 08:58 Manchester-Poole
1O74 09:58 Manchester-Brighton
1O19 08:05 Newcastle-Poole
1O25 09:50 Glasgow-Poole (Weymouth SO dated)
1O23 15:40 Liverpool-Poole
1V16 17:28 Manchester-Paddington
however there's clearly some errors because of the mis-match in numbers, so should probably include also
1O86 14:00 Leeds (Hull)-Brighton
1O62 06:01 Derby-Brighton
I think with these extra two the stock workings balance. Whether or not the stock matched the working timetable is a different issue.
Those were still non-air con Mark 2a/b/c sets in the 1984-85 timetable. I worked them regularly.
Interesting, the Carriage Working has them as a WR AC set:
NEA, 3 TSO, FK Leeds
TSOT, 2 TSO, BFK Hull
I've also seen a few photos of the Hull portion in 1984, and it has been AC stock bar one substitution of a Mk2A BFK and one of a 2C TSOT.
hexagon789
2 Sep 2016
Unless my memory is failing me I was under the impression that they didn't become AC sets until the May 1986 timetable. I'll dig out some of my old guard's train journals and have a look.
1985 has them as AC too, but with a Mk1 FO now in the formations.
BTW, I'm not doubting you I'm literally just quoting the Carriage Working books and some reference photos.
Perhaps PV stock subbed frequently?
Big Jumby 74
12 Feb 2022
The guard had to remember to announce that only the front six coaches would be platformed at Clapham Junction and it was a bit of a nightmare checking the doors and signal and then giving the right-away from the sharply-curving and unstaffed platform 16....especially when the brake vehicle was marshalled at the rear, which it usually was. Green flag from half-way across the platform opposite an open intermediate carriage door....then leap across into said open door and slam it behind you as the 47 pulls away. Health & Safety....what Health & Safety? Happy Days! :D
A bit of de-ja-vue has just walked across my memory.....!
As for p16 'Up The Junction', yes, on the 'UP' you will have been hanging out the back and blocking the Junction points below St. Johns Hill bridge.
Here's a view I took of the Southbound train in 1986, and as you will see a mix of Mk2a and Mk2d stock, the only firm certainty being the erstwhile BG...:D (Note: date etc is as I have recorded, but train HC and 'time' have had to rely on 'jfollows' post above, as this detail I did not have/note at the time).
  • BJ-47513, Friday 5th  September 1986. Clapham Junction with (1074, 09.58)  Manchester to Brigh...jpg
jfollows
26 Feb 2011
Wilmslow
September 1986 1O74 was 12:15 Manchester-Brighton non-air-con in the WTT I have from the time, and went via Birmingham then WCML, 16:14 at Clapham Junction (see http://1s76.com/).
D6130
12 Jan 2021
West Yorkshire/Tuscany
Some random formations from my Journals:
Wed 03/10/1984: 1M41: 47 443 + W92093/M5545/5420/5526/13543/6528/5546/5414/5565....Mark 2a/b/c non-AC stock.
Same date: 1O86: 47427 + W17081/5851/6119/6610/13582/6136/5857/M92029....Mark 2d/e/f AC stock.
Mon 22/04/1985: 1O62/1M07:47 608 + M92172/5372/5368/6523/13527/5403/5502/5505/5415....Mark 2a/b/c non-AC stock.
Same date. 1O74: 47 609 + M92114/5424/5418/5411/5604/13552/6527/5509/6517....predominantly Mark 2a/b/c non-AC stock.
Tue 23/04/1985: 1O74: 47 608 + M92027/13536/5522/5346/5366/5371/5582/6524/5428....Mark 2a/b/c non-AC stock.
Wed 24/04/1985: 1O74: 47 599 + M5541/5536/5427/5367/5532/5430/6529/13521/92227....Mark 2a/b/c non-AC stock.
Thu 25/04/1985: 1O74: 47 624 + M5310/5607/5581/5482/13555/6528/5560/5423/92199....Mark 2a/b/c non-AC stock.
From the above, we can conclude that the inbound evening arrival from Hull/Leeds and the following morning's outbound Manchester service were already an AC circuit....but the middle of the day arrivals and departures - 1O62/1M07/1074 & 1M41 - were still non-AC stock, regardless of what was written in the CWNs. The LMR must have had a shortage of AC stock at the time and cross-country services obviously had to play second fiddle - as ever was - to the West Coast Main Line!
Big Jumby 74
12 Feb 2022
The only other detail I have recorded relating to these services was a run I had up front with 47408 (D1507) on Sunday 6th March 83, when the train was the 09.55 off Gatwick, but only took it as far as Reading. Formation details now lost afraid.
D6130
12 Jan 2021
Ah yes....the Gateshead 'generators' got everyone once the HSTs Had taken over the ECML!
Taunton
1 Aug 2013
I seem to recollect a large advertising banner for this service on the parapet of one of the bridges on the route, possibly the bridge over North Pole Road in Shepherds Bush, at the time of the service.
Magdalia
1 Jan 2022
The Fens
1E54 had a Leeds portion 1L17 1135 from Sheffield, 1O86 had a Hull portion 1J01 1322 ex Hull.
1E54/1L17 and 1J01/1O86 were the same coaches.
The exile
31 Mar 2010
Somerset
Possibly dating from the recasting some time in the 80s which saw extra through services to Canterbury and somewhere else I’ve now forgotten. Didn’t last long
75A
31 Mar 2021
Ireland (ex Brighton 75A)
When I was a guard at Brighton - from November 1983 - the Brighton-Manchester/Wolverhampton trains used to run via Kensington Olympia and then onto the Great Western main Line at North Pole Junction. At that time we only worked them to and from East Croydon, relieving - or being relieved there by - Norwood Junction men, who worked to/from Reading. However the May 1986 timetable brought about a whole new scenario, with the early morning Northbound service from Brighton was diverted to run from Newhaven Marine - connecting with the overnight ferry from Dieppe - and formed of a nine car Mark 2d/e/f set in the then new Inter-City livery. This involved an early morning ECS working from Brighton to Newhaven Marine, where the guard had to uncouple and couple the running-round class 47/4 loco and then rapidly change out of his/her greasy overalls and gloves to perform commercial duties as presentably as possibly. This was also the time when the train gained a Clapham Junction stop and was diverted to run via the West Coast Main Line with a change to/from class 86/2 haulage at Willesden West Junction (Northbound) or Mitre Bridge Junction (Southbound)....and - of course - the poor old guard had to get dirty again uncoupling and coupling the two locos. Oh well....it kept us fit, I suppose! East Sussex commuters soon cottoned-on to this 'luxury' service and started driving to Newhaven - or joining at the new Haywards Heath stop - in large numbers for the 06 25 departure - enjoying coffee and a bacon roll in the buffet - before changing at Clapham Junction for either Victoria or Waterloo. The guard had to remember to announce that only the front six coaches would be platformed at Clapham Junction and it was a bit of a nightmare checking the doors and signal and then giving the right-away from the sharply-curving and unstaffed platform 16....especially when the brake vehicle was marshalled at the rear, which it usually was. Green flag from half-way across the platform opposite an open intermediate carriage door....then leap across into said open door and slam it behind you as the 47 pulls away. Health & Safety....what Health & Safety? Happy Days! :D
The Brighton footplate crew would be relieved @ Kensington Olympia both ways.
12LDA28C
14 Oct 2022
The back of beyond
So it was not long ago through videos that i found out apparently at one point crosscountry services had operated to Brighton before to Manchester.
i am curious now, what was the route it took to get from Brighton to Manchester? Does anybody know?
And its such a shame that this service is discontinued (its only from 2023 i came to the UK) and it will be such a good connection up north without changing trains.
The daytime out and back train 1O66 / 1M50 was a staple train for Class 47 haulage enthusiasts throughout the 1980s and 1990s as you could travel all the way to Brighton and have just enough time to have a quick wander around and get some lunch before returning north. CrossCountry retained a guards depot at Brighton and they worked this train Reading-Brighton-Reading. Some I recall were 'friendlier' than others!
Taunton
1 Aug 2013
The Brighton-Cardiff was still twice daily with FGW until a few years ago
This seemed to have various destinations. Some years ago I saw a 158 in Brighton station with a destination of Great Malvern showing, which I thought must be an error but turned out to be correct. Basically the Brighton to Bristol services were being combined with Bristol to Worcester, but then extended beyond there to Great Malvern, where after about a 5 hour run and having intersected half of all the main lines out of London they had just a few minutes turnround before doing it all back the same way.
It seemed all an Orcats Raid on the local Worcester to Malvern flow. The chances of getting to Worcester on time were inevitably poor, and it was very regularly truncated there to skip this final stage. There must be something in the revenue attribution calculation, and the cancellations reporting, to have made this plan nevertheless worthwhile.
75A
31 Mar 2021
My memories of 47's as a Brighton secondman was wiping my feet on the way out, they were disgusting particularly compared to our usual ES'ds
Gloster
4 Sep 2020
Up the creek
Getting it on to or, worse, off the GWML was an absolute pain as it crawled around the corner to and from North Pole: it was an excellent (terrible, depending on your point of view) example of how one train getting just a bit out of its path could cause disruption that took a long time to sort out. I visited North Pole box once: it was the barest box I have ever been in.
Sad Sprinter
5 Jun 2017
Way on down South London town
I remember seeing a Voyager run down the bank from the Crystal Palace to Beckenham Junction branch onto the Brighton Main at Norwood one night in 2008 - which made a very bizarre sight!
To echo others, I am sure I have a 1988 timetable with a Brighton to Manchester via WCML service. There's a Youtube video of trains in Rugby sometime in the late 80s with that train passing through, and as I recall it was hauled by a class 47.
TrainBoy98
19 Mar 2012
Worthing
Think there was quite a few "odd" places they ended up due to diversions etc. I remember one of the first times I saw a Voyager was passing Havant on the Westcoastway
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
I took this train once - I will look in my records for haulage etc. When I took it, the train went on the WCML and then to Kensington Olympia. Traction changed over at Mitre Bridge area. I will dig my records out.
Davester50
22 Feb 2021
It might not be the one you're thinking of, but Adrian Nicholls shot I've linked below of the Kenny O footbridge with InterCity advert is the one that sprung to my mind.
Kensington Olympia 1987
Obviously not my photo.
LudwigTails
31 Mar 2023
Brighton
how long has the service been deceased for I am wondering.
After this i am honestly considering trying to recreate this route myself. (As in riding current day trains and route to sort of recreate the line).
Kinda wish this service can come back tbh.
Mcr Warrior
8 Jan 2009
The most tricky part of the 2000's version of the Brighton -> Manchester Piccadilly route will be the section from Kensington Olympia to Reading. The rest is all very much still do-able, including the via Redhill/Guildford variant.
MontyP
18 Nov 2015
From autumn 85 until summer 86 I lived in a university hall of residence in Swaythling with a fantastic view of the line into Southampton. My memory is that practically all the inter cities to Poole were air con by then.
30 Jul 2015
On Summer Friday nights in 1988 there was a Manchester - Weymouth overnight routed via New St, WCML, Gatwick, Hove and Southampton. It didn't go to Brighton station, but it did go through the Brighton conurbation. It was also diesel hauled from New St which was fairly unusual over the southern WCML in those days.
LudwigTails
31 Mar 2023
Brighton
are there any variant that doesnt go through reading? or most of them does?
