JohnMcL7
- Joined
- 18 Apr 2018
- Messages
- 864
Agreed and also I'd add that copper landlines are nowhere near as bulletproof as people are claiming since a storm that has taken down power could also have taken down the landline which has happened several times for some of my friends who live in rural areas. In reality I've had far more problems with copper landlines in general usage than I have had with complete power outages as on a couple of occasions I've been without a landline until I could get an engineer to the house to check it and then fix whatever had gone wrong down at the exchange.Basically the only real world actual important downside to note is the lack of a backup power source for blackouts (which generally isn't needed for regular PSTN connections). How much that actually matters is very much dependent on the individual and where the live, but I will say the last time I had a power cut that lasted more than a single digit number of minutes was quite a few years ago now and even then I still had mobile signal just fine so I'm not convinced it is something that most of us need to worry about (in the same way that the whole "cash is king" folk seem to talk about power cuts and entire card network failures all of the time, the actual chance of you being caught up in an event like that is pretty slim!). I do however think care needs to be given for those where this may be an issue, I'm specifically thinking of elderly folk who may rely on things like personal alarms, but even they are being replaced with digital ones that connect to the mobile phone networks these days.
Looking at the comments above it highlights BT need to do a better job explaining why they have to remove PSTN services as there are very genuine reasons that are forcing them to do it rather than then ill thought out vindictive move some are seeing it as.
