BVE4 MTU HST Not working :(
SuperVoyager
8 Mar 2008
Fife
Hi,
Got the mtu for bve, all installed. open it up in bve but there is nothing there, it just white. all other trains work fine, anything i should be doing? Thanks
devon_metro
11 Oct 2005
There isn't officially a BVE4 MTU, its designed for openBVE. Hence might cause you grief.
Wim G.P.R
7 Aug 2006
CARDIFF
The MTU is a Open bve only train the config does not work in reverse, ie Open to bve4.
Where as bve4 and 2 trains will run in Open but there may be problems as the config needs changing to work in open properly.
Also not all Open trains work in bve4.
Only Open trains that have a bve4 type of config, infact most UK trains are bve4 altered for Open!
Steve T.
2 Dec 2007
Just take the sounds and shift out the old ones, thats what I did when using BVE4, openbve is far better in terms of graphics
MCR247
7 Nov 2008
try it on open bve.
Pumbaa
19 Feb 2008
Must be my graphics card then cos it all opens up but is just frozen<(
Might have been your installation ;) do it again, follow the instructions to the letter and ask if you don't have a scoobies.
