Carto Metro map London v4.3 now online
Rogmi
7 Nov 2013
Franklin has just uploaded v4.3 of the London map
view the interractive map online or download the PDF version (recommended for home PC use)
Note - To download the PDF
On the CM page, RIGHT CLICK on the PDF link, then SAVE AS to download the PDF file. If you just click on the PDF link, the browser may open it (a very slow process) rather than giving the option to save it.
rebmcr
15 Nov 2011
St Neots
Is there a changelog?
One thing for the next edition: The Kennington Loop should lose its single-direction arrow.
43096
23 Nov 2015
The Heathrow Express depot and Old Oak Common depot connections can be removed as well. Just the Elizabeth line depot on site now.
stuu
2 Sep 2011
Why? It's still in use and still works in the same direction
bakerstreet
29 Nov 2009
Does anyone have a map which shows how the Overground used to arrive at the platforms at Stratford close to the Jubilee line?
I can’t see how this used to occur, although I know it did !
AM9
13 May 2014
St Albans
I don't have a map but broadly, from Stratford Market, it followed what is now the DLR formation up to Stratford (platforms 16 & 17), and then underneath the GEML. There was a 'y' junction on the north side, with the left branch swinging westwards and joining the NLL (the right branch went towards the Lea Valley line), but the junction has been removed and the raft on which the Westfield Shopping centre is built covers the track until just before the location of the main NLL is reached. A trip on the stub of the DLR to Stratford International is weel worth it to see where the line went. There is very little flow between the two stations so it shouldn't be difficult getting a front seat.
If you can load this link;
https://maps.nls.uk/geo/explore/sid...1.54468&lon=-0.00561&layers=1&right=ESRIWorld
on the excellent NSL site, my explanation should be clearer.
Mikey C
11 Feb 2013
OpenRailMap has the chord which used to connect it to the track to the low level platforms
Taunton
1 Aug 2013
Above notes are correct. The whole of the DLR from Canning Town to the last 200 metres or so where it bends into the International terminal platforms is built on the old Overground/BR/GER alignment. The Jubilee Line alongside much of this was opened well before the Overground service was given up (2007 I think), essentially to allow its conversion to the DLR - and also because hardly anyone used this easternmost part. Where the DLR comes right alongside the NR lines between Stratford and International is where the tracks used to link up. There are cabfront videos on Youtube that show how it was (and all 3rd rail).
Mikey C
11 Feb 2013
The DLR extension to George V (and later Woolwich Arsenal) in 2004 took most of the Stratford to North Woolwich traffic, enabling its closure in 2006. Before that it was reasonably well used, but less than the rest of the North London Line.
Dstock7080
17 Feb 2010
West London
Ok thanks. How does that actually work in practice?
The first trains in the morning from Battersea run to Kennington NB then run empty around the loop to Kennington SB, to provide the next service back to Battersea
stuu
2 Sep 2011
ah ok, thanks. One for the rare track people then
bakerstreet
29 Nov 2009
Thank you I’ll take a look
rebmcr
15 Nov 2011
St Neots
I don't think passengers are allowed to use the Kennington Loop in either direction.
It's a grey area, they're not required to thoroughly de-train, but they also don't like to take passengers through (partly because trains can be re-timed there and sit in the tunnel for quite a while). Many enthusiasts have deliberately done it, with no fuss.
Whether they are stricter with the wrong-direction moves (and indeed at a much quieter time of day when it would be more difficult to escape the attention of platform staff) I am not sure.
They are cleared for passenger use as it's generally not practicable to sweep the trains due to the tight headways.
It's very much unofficial from a passenger point of view, though and there is of course no right to be conveyed by it and if someone tells you to alight, you'd need to do that.
MikeWh
15 Jun 2010
Crayford
When you're on a normal Kennington terminator going round the loop the displays (and possibly announcements too) explain that you'll shortly arrive back at Kennington. Presumably this is to allay fears of someone who has just woken up. The chances of being found before departure early in the morning on a reverse direction trip are much higher because the train actually changes direction, thus spends more time in the platform before departing.
Rogmi
7 Nov 2013
Thanks, people, for the changes comments, I'll pass them on to Franklin.
No changelog as such, but these are the changes since v4.2
There's very few changes since the map was updated when the Elizabeth line opened.
4.3 now shows the Barking Riverside extension as open (although there were no trains running from there for a big chunk of yesterday due to problems elsewhere on the line, and no service again today (Tuesday) because of different problems shutting down the Goblin all day.)!
The Ripple Lane area updated following changes to the layout because of the extension
Northen line:
- minor positioning of a crossover at Golders green
- addition of disused crossover between 18 and 19 roads at Morden depot and
- shortening of 18 road and show disused crossover back of 18 road to 17rd
- site of Weston Street C&SLRly signal cabin added
- 'Under the wall' name added to disused siding at Finchley Central
- disused crossovers added south of Camden Town (this was the original route before the C&SLRly was extended from Euston)
- Pudding Mill Lane Junction name added at Stratford
MikeWh
15 Jun 2010
Crayford
Another thing that's slightly out of date is the description of the NR lines approaching London Bridge. They seem to be those in use while the station was being rebuilt.
Rogmi
7 Nov 2013
Thanks
You're right about that, that was done during the changes when it was a mix of new and old layout.
The London lines map is a bit more up to date, but still need some changes to the naming of the London Bridge and Blackfriars tracks.
I'll check out the current SA
90sWereBetter
13 Nov 2012
Always love the Carto maps, thanks for all your work on this.
Would there be any possibility of slightly extending the southern border of the map in future to include Purley in full, along with the Caterham and Tattenham Corner lines? Almost all other railways within the M25 are covered bar these two lines.
Rogmi
7 Nov 2013
Franklin is the one that does the map. I'll pass your comments on to him (or he may read this thread). There may be a physical size limit for the map which makes it unrealistic to expand any further, especially as this would mean extending it vertically about 4 miles.
