southernyoshi
- Joined
- 12 Sep 2014
- Messages
- 156
Hello - I'm wanting to sample the 395 as it's meant to be - blasting across Kent at 140mph. I want to know what's the cheapest way of using HS1 from a start at Worthing - I'm sort of thinking a loop of Worthing - Brighton - Ashford - Ebbsfleet - Strood - Tonbridge - Redhill - Gatwick - Worthing. Or maybe the reverse, going to Ebbsfleet via Clapham, Denmark Hill & Medway (as apparently that doesn't count as London ) then down to Ashford. Or can you use Boundary Zone 6 on HS1? I've tried NRE but getting it to do Worthing - anywhere in north Kent without it telling you to go into Victoria & out is...not made easy. I would've thought just Worthing - Strood or somewhere like that would give what I'm after as the quickest route but no. Thank you
