thats a top cab so cab see both ends vs a full size locomotive but only one cab at one endIs that not the Class 18 as described above?
The single cab was part of the Type A (later Type 1) pilot scheme specification laid down by the British Transport Commission, along with no steam heating and a power output of up to 1000hp. The single cab and absence of a boiler saved weight, not only of those components themselves, but because a shorter frame was needed to support them.As well as cost saving they were built in an era when single cabbed locos (i.e steam) were the norm. Would a class 20 type layout meet current safety requirements if being introduced today? The class 18s have a central cab with much lower bonnet either side.
Can't speak for here but I know it's still officially permitted in Australia (and on much longer locomotives to boot), though in recent times it's actively discouraged except for shunting and other short-distance/low-speed moves.As well as cost saving they were built in an era when single cabbed locos (i.e steam) were the norm. Would a class 20 type layout meet current safety requirements if being introduced today? The class 18s have a central cab with much lower bonnet either side.
The whole Type A/Type 1 saga is one of the biggest, if not the biggest, wastes of money of the Modernisation Plan.The single cab was part of the Type A (later Type 1) pilot scheme specification laid down by the British Transport Commission, along with no steam heating and a power output of up to 1000hp. The single cab and absence of a boiler saved weight, not only of those components themselves, but because a shorter frame was needed to support them.
why were they designed like that, with a thin cab one end and not with cabs both ends?
Cheaper to fit one cab rather than two.
It is important to remember what the Type As were originally for. In the mid 1950s nearly every rural branch line had a daily pick up freight which brought coal in and took agricultural produce out. The Type As were to replace steam on these workings.As well as cost saving they were built in an era when single cabbed locos (i.e steam) were the norm.
No, the EE Type 1 is designed for driving in both directions.Quite the opposite, the 20 is designed for driving with the cabbed (no.2 end) leading, but the cab does feature dual controls. In fact in BR days I believe a secondman was required when driving 'nose first' to assist with signal sighting.
If I remember correctly from their first year of introduction, photos generally showed them single unit, and running long-nose-forward on both passenger and freight (and when lined up well polished to show dignitaries). Little driving difference to a steam loco of course.
While the D82xx and D84xx locos had the three quarters position, the EE Type 1 had the cab at one end. This was one of it major drawbacks and why BR stopped orders after D8128. They then disappeared down the Clayton and Paxman rabbit holes, both of which were designed to provide good all round visibility for working branch line trip freights.English Electric did a range of exports, eg to Australia, with the cab at the three-quarters position, and long and short noses, just like a USA road switcher or D8200/8400.
I don't want to create a new thread for this so i'll ask here.
In pairs Class 20s always travel cabs outer, but has anyone ever seen a pair operating with bonnets outer? I'm sure it must have happened at least once over their long careers though never seen photographic evidence!
Not when the locomotives were new.the normal method of operation is No. 2 end (cab) leading
When the locomotives were new there was no intention to use them to haul a decent load on main lines. In the early days the EE type 1s were primarily used singly on trip freights and branch line pick up freights, which were lightly loaded. It is very rare to find a picture of a pair before the end of steam.a single loco was not sufficient for hauling a decent load
I agree with this bit, but it only happened to a significant extent after the end of steam, and the closure of many branch lines after Beeching. It was at that point that the EE Type 1s were repurposed to operate in pairs as a surrogate Type 4 with lots of brake force.pairs were almost always coupled with cabs outwards
Although they were fittted with headcode panels at both ends, suggesting that running bonnet first in main line use was envisaged.The second build locos, with headcode panels, and delivered in 1966-68, saw very little of the original method of operation, especially the D8144-99 batch that went new to Toton.
Wasn't part of the "limited visibility" design on these, as well as things like 37's with a bonnet and relatively small windows, to replicate the view from the footplate of a steam locomotive, thus making the transition from steam to diesel slightly easier for the crews, or is that just a myth?
That's the one. I knew it was something along those linesNever heard that before. The Class 20 was possibly derived from steam locomotive design hence the single cab but locomotives with a 'nose' like 37s, 40s, 44-46s, 55s were so designed to prevent the driver being able to see straight down onto the track in order to reduce the effect of 'sleeper flutter' at speed until it was ascertained that the effects of this phenomenon were not as severe as first thought.
I don't think so.Wasn't part of the "limited visibility" design on these, as well as things like 37's with a bonnet and relatively small windows, to replicate the view from the footplate of a steam locomotive, thus making the transition from steam to diesel slightly easier for the crews, or is that just a myth?
I have not seen anything that examined that. Intuitively a pair of class 20s would have higher running costs than a single class 40 but that's probably more than offset by the increased payload. With heavy unfitted freight trains running at low speed the maximum weight carried is determined by brake force not horse power.Out of interest, how did this compare in terms of running costs to something like a 40?
A Class 40 weighs 135 tonnes, two class 20s weigh 146 tonnes. Moreover, all eight axles are powered, so traction will be better than the 1Co-Co1 Class 40, in which two of the eight axles are unpowered.I have not seen anything that examined that. Intuitively a pair of class 20s would have higher running costs than a single class 40 but that's probably more than offset by the increased payload. With heavy unfitted freight trains running at low speed the maximum weight carried is determined by brake force not horse power.
Am I not correct that the Class 40 unpowered wheels are not braked either?A Class 40 weighs 135 tonnes, two class 20s weigh 146 tonnes. Moreover, all eight axles are powered, so traction will be better than the 1Co-Co1 Class 40, in which two of the eight axles are unpowered.
Yes that's correct, hence the lower brake force.Class 40 unpowered wheels are not braked either?
